Introduction: Arduino Potentiometer+RGB LED Van Gogh Escape Room Light Show
In this escape room, I take famous artist Vincent Van Gogh's iconic color scheme and let those colors shine with an RGB LED.
1 Arduino
1 breadboard
1 potentiometer
1 RGB LED
1 Resister
10 Jumper Cables
Step 1: Setting Up the Code
  • The code you will be putting in will control the RGB LED and the potentiometer
  • Once the simulation is started the potentiometer will be able to be turned
  • Turning all the way to the left will make the RGB LED shine yellow
  • Turning all the way to the right will turn the RGB LED shine blue
Step 2: Setting Up the Hardware
RGB LED
  • Place the RBG LED on e4-e7
  • Place a resister on b5 and a negative line on your breadboard
  • Red jumper cable from 12 to b4
  • Blue jumper cable from 13 to b6
  • Green jumper cable from -11 to b7
Potentiometer
  • Place potentiometer on e16 to e18
  • Black jumper c16 to the negative line on the breadboard
  • Green jumper cable from c17 to A0 on the Arduino
  • Red jumper c16 to the positive line on the breadboard
  • Connect a red jumper cable from 5V to the positive line on the right side of the breadboard
  • Connect a black jumper cable from the GRD to the negative line on the right side of the breadboard
  • Connect the left and right sides of the breadboard by placing a red jumper on the left positive line to the right positive line
  • Do the same with the negative but on the negative lines on the breadboard
Step 3: Playing the Escape Room
