Introduction: Arduino Powered Dog Food Dispenser
If your house is anything like mine, some tasks may be forgotten when in a rush. Don't let it be your pet that gets forgotten about! This automated dog food dispenser uses an Arduino to deliver the right amount of kibble at the right time. All parts are custom designed to fit and work together. It is also designed to fit in well to a space without looking tacky.
Materials:
- 2x Front Plate(Laser Cut)
- 2x Side Plate(Laser Cut)
- 1x Top Plate(Laser Cut)
- 2x Curved Slope Piece(3D Print)
- 1x Gear Piece(3D Print)
- 1x Arduino
- 1x Arduino Standard Servo
- 3x Arduino Jumper Wires
- 1x Mechanical Count Down Timer
- Hot Glue Gun & Glue
- 4x Nails
Step 1: Step 1: 3D Print
For this project, it is very important that all parts are to the same ratio. If you want to, you can use your own design or you can use my design. Make sure measurements are all in inches before printing.
Step 2: Step 2: Laser Cut
Now Laser cut the designated pieces. I used wood, but acrylic would work well too. Remember to use animal friendly materials. For mine the wood is 0.25 inches thick, I recommend that so you don't have to resale anything. Due to the size of the front piece you may have to cut on more than one sheet.
Step 3: Step 3: Sand and Fit
When using both a laser cutter and a 3D printer, be prepared to sand.Once sanded, the curved piece should fit tightly into the side piece, as seen in the picture. For mine, hot glue is not necessary for this step, but would be a good idea.
Step 4: Step 4: Fit Side Pieces in and Glue
Now it is time to fit the side pieces into one of the front pieces. Hold them in place as you hot glue them into place.
Step 5: Step 5: Add Top Panel and Glue
Now it is time to add the top panel. Once in place, securely glue it.
Step 6: Step 6: Insert Gear
This may take a lot of sanding too, depending on the quality of the print. The short peg of the gear will fit into the hole of the front panel. Do not glue this piece.
Step 7: Step 7: Attach Front Piece
This piece is going to be a bit more difficult to fit. Make sure the long peg of the gear fits through the hole. Test to make sure the gear can move easily, and with little force. If it doesn't fit, sand the gear more.
Step 8: Step 8: Nail in the Front Panel
This is important in case you need to remove the panel later. The nails I used were very thin and are used to secure the front piece to the side pieces. Make sure that when hammering the nail enters into the side panel and not just through the front.
Step 9: Step 9: Connect Your Servo and Arduino
In the image I used a mini servo. It works much better to use a standard servo. Glue the servo's tip in/onto the section of the gear. Secure the servo's position so the gear will rotate instead of the servo. Then attach the arduino to either the back or side. If you wish to cover them up(suggested), make sure that arduino is still accessable and the power cord is available. The code used is a single 90 degree rotation.
Step 10: Step 10: Attach to Power Source
Use an outlet timer, after following instructions on package and following the directions, set times for dispenser. I used 6 am and 6 pm, but any works. If you do not have a timer you can programm your arduino to perform an interupt, but it is more complicated. I highly suggest using an outlet as your power supply, but it could function on battery for some time.
I am using a screwed on hanger to attach it to the wall, but this is an extra step.
Epilog Challenge 9
2 years ago
What a fun project! My dog would smell the extra food and find a way inside. :)
