Introduction: Arduino Project: Random Electronic Dice
Hello!
This project was built for an assignment for my college.
It was born from my interest in D&D and the use of dice in that roleplaying game.
It is an electronic die, which randomly chooses a type of die (having the options of a 4, 6, 8, 10 or 12 sided-die) and then randomly chooses a number on that die.
Step 1: Gathering Materials
For this project, you need
- An Arduino Uno with USB cable
- 12 LED-lights (any colour)
- 25 wires (preferably
- A soldering prototyping board or a solderless breadboard
- One 560 Ω resistor
You can get all of these items in a normal Arduino starting kit.
Step 2: Connecting the Wires
Putting this project together is really simple.
Each of your LEDs has to be connected to a node on the Arduino through a wire. The given schematic only has six LEDs, but this can easily be expanded to twelve by using up to the twelfth digital pin on the Arduino.
Another set of wires leads away from the LEDs, and comes together at the resistor. If you're using a solderless breadboard, it'll be enough to put them all on the - strip on the side; if you're soldering the thing, you'll have to connect the wires through solder.
Another wire leads from the resistor to the Ground pin on the Arduino.
Step 3: Writing the Code
This is the code I used;
void setup()
randomSeed(analogRead(0));
for ( int z = 1 ; z < 13 ; z++ ) // LEDs on pins 1-12 are output
pinMode(z, OUTPUT);
void randomLED(int del, int d) //int del indicates the delay, int d indicates which type of die is/how many LEDs are being used
int r;
if (d == 1){
r = random(1, 5); //get a random number from 1-4
if (d == 2){
r = random(1, 7); //get a random number from 1-6
if (d == 3){
r = random(1, 9); //get a random number from 1-8
if (d == 4){
r = random(1, 11); //get a random number from 1-10
if (d == 5){
r = random(1, 13); //get a random number from 1-12
digitalWrite(r, HIGH); //output to the LED matching the randomly generated number
if (del > 0)
delay(del); //hold the LED for the amount of delay that is given
else if (del == 0)
do //with 0 delay given, hold the LED forever
while (1);
digitalWrite(r, LOW); //turn off the LED
void loop()
int a; //cycle through LEDs to simulate the rolling of the die
int d = random(1, 6); //choose how many sides you're using (see the if-statements above)
for ( a = 0 ; a < 50 ; a++ ) //cycle through 50 LEDs
randomLED(50, d); //delay is 50 milliseconds, int d has been chosen earlier in the void loop
for ( a = 1 ; a <= 5 ; a++ ) //cycle through 5 LEDs
randomLED(a * 100, d); //delay is 100 milliseconds
randomLED(0, d); //display the definite LED
Step 4: Go Further!
You now have a working randomly generating electronic dice!
You can build further on this idea by, for example, making it possible to choose which die you're using. Or you can build a beautiful case for it to shine through.
