Introduction: Arduino RDM Relay
So far I have been using DMX but that meant I would have to reprogram my arduino every time I want to change the DMX start address so I decided to switch to RDM.
Step 1: Gather the Parts
- MAX485 (RS485 tranciever)
- Female and male xlr's
- Arduino uno rev3
- Relay of your choice
- N-channel mosfet
- led
- 4.7k Ω resistor
- 220 Ω resistor
- Breadboard or pcb
- Jumper wires
- DMX/RDM tester
- 12 volt power supply
Step 2: Build the Circuit
Step 3: Arduino Code
- install the DMXSerial2 library using the library manager
- upload the code
Step 4: Test the Device
For testing this device you will need an RDM tester or controller
- plug your RDM relay into your RDM tester or controller
- power them both up and then you can check if the device is listed in your RDM tester or controllers device list
