Introduction: Arduino RGB LED Strip Controller
Often when people want to control their RGB LED strip with an Arduino, three potentiometers are used to mix the red, green and blue colors. This works and could be perfectly fine for your needs, but I wanted to make something more intuitive, something like a color wheel.
This project seems to be a perfect application for a rotary encoder. This is a device that converts the motion of its shaft to a digital output. When the shaft is turned, the encoder sends out a signal (pulse) which can be measured by an Arduino. For more on rotary encoders, you can watch this video which explains it more in-depth.
In this Instructable I will show you how to make an Arduino RGB LED strip controller by using a rotary encoder. This Instructable covers the construction of the circuit on a breadboard. You could however produce your own PCB in order to create an Arduino shield!
Step 1: Parts
For the RGB LED strip controller you will need the following materials:
- 1x Arduino Nano
- 3x IRLB8721PBF, any N-channel logic level MOSFET will do as long as it is rated at a minimum of 12V and the current your LED strip consumes.
- 1x Rotary encoder
- 1x 12V 2A power supply, the current the power supply has to deliver may depend on the length of the used LED strip.
- 16x Male to male jumper wires
- 1x Solderless breadboard, any breadboard will do as long as it is sufficiently large.
Step 2: Circuit
Connect the Arduino to the 12V and GND rail of the breadboard. Then connect the other parts as follows:
Rotary encoder
Pin A - D4
Pin B - D3
GND - GND
MOSFET Red
Gate - GND
Drain - LED strip red wire
Source - D11
MOSFET Green
Gate - GND
Drain - LED strip green wire
Source - D9
MOSFET Blue
Gate - GND
Drain - LED strip blue wire
Source - D6
Step 3: Code
// Arduino PWM pins
int redPin = 11;
int greenPin = 6;
int bluePin = 9;
// Arduino encoder pins
int encoderPinA = 3;
int encoderPinB = 4;
// Color variables
int colorVal;
int redVal;
int greenVal;
int blueVal;
// Encoder variables
int encoderPos;
int encoderPinACurrent;
int encoderPinALast = HIGH;
// Other
int counter;
void setup(){
pinMode(encoderPinA,INPUT_PULLUP);
pinMode(encoderPinB,INPUT_PULLUP);
void loop(){
readEncoder();
encoder2rgb(counter);
analogWrite(redPin, redVal);
analogWrite(greenPin, greenVal);
analogWrite(bluePin, blueVal);
int readEncoder(){
encoderPinACurrent = digitalRead(encoderPinA);
if ((encoderPinALast == LOW) && (encoderPinACurrent == HIGH)){
if (digitalRead(encoderPinB) == LOW){
encoderPos = encoderPos - 1;
else {
encoderPos = encoderPos + 1;
encoderPinALast = encoderPinACurrent;
counter = encoderPos*8;
if (counter < 0){
counter = 1535;
else if (counter > 1535){
counter = 0;
return counter;
int encoder2rgb(int counterVal){
// Red to yellow
if (counterVal <= 255){
colorVal = counterVal;
redVal = 255;
greenVal = colorVal;
blueVal = 0;
// Yellow to green
else if (counterVal <= 511){
colorVal = counterVal - 256;
redVal = 255 - colorVal;
greenVal = 255;
blueVal = 0;
// Green to cyan
else if (counterVal <= 767){
colorVal = counterVal - 512;
redVal = 0;
greenVal = 255;
blueVal = colorVal;
// Cyan to blue
else if (counterVal <= 1023){
colorVal = counterVal - 768;
redVal = 0;
greenVal = 255 - colorVal;
blueVal = 255;
// Blue to magenta
else if (counterVal <= 1279){
colorVal = counterVal - 1024;
redVal = colorVal;
greenVal = 0;
blueVal = 255;
// Magenta to red
else{
colorVal = counterVal - 1280;
redVal = 255;
greenVal = 0;
blueVal = 255 - colorVal;
return redVal, greenVal, blueVal;
}Attachments
Step 4: Result
After uploading the code, you should be able to control the RGB LED strip by turning the rotary encoder clockwise or counterclockwise. Enjoy!
