Introduction: Arduino Repeat Cycle Timer
This is an arduino based repeating cycle timer. The times are set in the sketch and cannot be modified during operation.
It is durable, reliable, simple and cheaper than a comparable unit.
This relay is rated for 10 amps. The relay will melt if you exceed the maximum load. a space heater, water pump or large fan will draw more current and should be used carefully.
Step 1: Arduino Repeat Cycle Timer
The parts list:
Arduino: 26$
http://www.canadarobotix.com/arduino-microcontroll...
1 Channel Relay: 5$
http://www.canadarobotix.com/mechanical-switches/1...
Project Box: 6$
http://www.walmart.ca/en/ip/lock-lock-800-ml-recta...
Re-purposed Xbox 360 cord: Free$
Cable Grip: 2.5$
http://www.digikey.ca/product-search/en/cables-wir...
Jumper wire kit: 13$
http://www.digikey.ca/product-detail/en/bud-indust...
Outlet: 1$
https://www.lowes.ca/building-supplies/electrical/...
I've used some risers for the relay and rigged my own risers for the Arduino from a Windex bottle straw and some nuts and bolts
Step 2: Install Into Box and Wire
i'd like to make a fancy wiring diagram with http://fritzing.org/home/ and add it here but....
The 12v wiring is
3.3v to VCC
Gnd to gnd
Pin 2 to IN
For the 120 v I've included a image of how I've wired the relay. you just run the common wire into the centre of the relay and then connect the N/C (normally closed) side of the terminal block to the outlet.
maybe ill update my Instructable with some diagrams in the future but for now this is what you get.
first I used a drill and file to create a hole for USB port and dc barrel jack to fit
second I marked the arduino's holes on the bottom of the project box for the risers to go into.
I've used a lighter and hair dry to soften the plastic when reaming or threading any holes to avoid the plastic cracking
I've also used a lighter the soften the risers into the plastic
I've also added a few air holes to allow heat to escape the box and used the cord grip to secure the power source the relay will get hot
I then used my dremel to cut the lid of the box to allow the 120v outlet fit.
Step 3: The Code
Here is the code
Change the offTime and onTime values to adjust the cycle times they are in milliseconds here's a link to a converter
https://www.google.ca/?ion=1&espv=2#q=minutes%20to...
I have plagiarized this code from other arduino projects and it works. the other project included multiple simultaneous functions and inputs this one does not.
I am aware of the the option to use delay instead of complex timer values and math.
