Introduction: Arduino Robot Control Console Program With the Visual Basic
We will do our robot console to manage this project with Visual Basic.
We will manage our robot via Bluetooth.
Tools Required to our form:
- 13 Number Button
- 2 Number combobox
- 1 Piece texbox
- 1 Piece GroupBox
- 1 Piece SerialPort
http://make.robimek.com/arduino-making-robot-control-console-program/
Step 1: Part of Our Form Design:
You can design in this way.
Step 2: System Library:
- First, we add to the system library.
Imports System.IO
Imports System
Imports System.ComponentModel
Imports System.ThreadingI
mports System.IO.Ports
Step 3: Form Load
Form part of the loader are adding value to serial port and baud rate.
myPort =IO.Ports.SerialPort.GetPortNames()
ComboBox2.Items.Add(9600)
ComboBox2.Items.Add(19200)
ComboBox2.Items.Add(38400)
ComboBox2.Items.Add(57600)
ComboBox2.Items.Add(115200)
For i = 0 To UBound(myPort)
ComboBox1.Items.Add(myPort(i))
Next
ComboBox1.Text = ComboBox1.Items.Item(0)
ComboBox2.Text = ComboBox2.Items.Item(0)
Button12.Enabled = False
Step 4: Serial Port
We define the serial port object.
Dim myPort As Array
Delegate Sub SetTextCallback(ByVal [text]As String)
Shared _continue As Boolean
Shared _serialPort As SerialPort
Step 5: Connect Button
Let's connect button to define the task of the port.
SerialPort1.PortName = ComboBox1.Text
SerialPort1.BaudRate = ComboBox2.Text
SerialPort1.Parity = IO.Ports.Parity.None
SerialPort1.StopBits = IO.Ports.StopBits.One
SerialPort1.DataBits = 8
SerialPort1.Open()
Button13.Enabled = False
Button12.Enabled = True
Step 6: Disconnect Buton
Let us define the disconnect button to terminate the connection with the robot.
SerialPort1.Close()
Button13.Enabled = True
Step 7: Serial Port ComboBox
Let us define the ComboBox to see one of the open ports.
If SerialPort1.IsOpen = False Then
Else
MsgBox(“It will not be changed while port open!”, vbCritical)
End If
Step 8: Baudrate ComboBox
Let us define the ComboBox other to set the Baud Rate for our values.
Else
End If
Step 9: Directional Buttons
We are doing our definition of the direction buttons.
A value different from each serial port will send button we press the button. For example we press the forward button one value, you send two values we press the back button. Let us for example to define a button.
SerialPort1.Write(“2″)
Here, we print the value 2 serial ports.
Other buttons will need to değerinideğiştirerek data only for identification.
Step 10: Keyboard Key Assignments From
Finally, it will be enough to change if you want to manage from your robot keyboard key priorities that part KeyDown the features section of the form true structure and the following description of the KeyDown of the form add these definitions is just a button içindir.dig button while the identification of button name and keyboard keys.
If (e.KeyCode = Keys.A) Then
Button1.PerformClick()
Button1.BackColor = Color.Red
TextBox1.Text = “Go Left”
Else
Button1.BackColor = Color.Yellow
End If
It also shows the status of the robot when the button is pressed, and we have done here in the definition to change the color of the button.
Step 11: More İnformation
More İnformation and example robot control :http://make.robimek.com/arduino-making-robot-control-console-program/
