Arduino Robotic Hand With Haptic Feedback
20,179
66
18
Introduction: Arduino Robotic Hand With Haptic Feedback
About: I enjoy working on all sorts of projects. Whether it is creating something with my forge or building the biggest thing I can think of in Minecraft, I am always trying to find new and interesting projects to wo…
This year for science fair, I did an engineering project with the goal of creating a system to provide haptic feedback from a robotic hand. The robotic hand is controlled by flex resistors on a glove worn on someone's hand, and an Arduino converts finger positions on the glove to finger positions on the robotic hand. Each of the fingertips of the robotic hand have their own force sensitive resistors(FSR) to gather information about pressure at each fingertip, and another Arduino converts the pressures to pulses for vibrator motors located on the fingers of the control gloves. I used two separate Arduinos since they only have 6 analog inputs each, and I needed 8. It also helped simplify the code a bit, since I used one Arduino for controlling the finger positions and the other for controlling the motor pulses. Also, I already had the two Arduinos, so I used them instead of buying an Arduino Mega or multiplexers. Anyway, the pressure readings are taken once every second, and the motors are on for a portion of each second depending on the pressure measurements. This means that the system is only accurate for a little bit each second, but the measurement intervals could easily be changed in the code.
For the robotic hand, I sketched up a basic design in Autodesk and used the assembler feature to play around with and fine tune some of the finger measurements. Once I had my design ready, I took it to my local hackerspace and got all of the parts laser cut out of an acrylic sheet that was about 5mm in thickness. I bolted all of the finger parts together. As for attaching the fingers to the palm, I scratched the areas where the acrylic overlapped and glued the parts together. The glue worked fine, but if I build another hand, they will be bolted on. There were also a few issues with the placement of holes on the finger segments, but a bit of glue helped anchor the bolts down. To avoid this problem on later designs, I will use smaller bolts and try to cut out as much overlapping material as possible.
For wiring everything together, I found stripped CAT-5 cable rather convenient. It is a little stiff, but it comes out as pre-twisted pairs of wire.
Also, there are only four fingers on the hand since there was only room for four servos on the palm area. To get a thumb in future designs, I will either move one of the robotic fingers to the side and move the sensors around on the glove, or just buy some smaller servos to make everything fit.
In all, the project turned out well and provided a great starting point for future projects. I will eventually come back to this project, and when I do, I will definitely turn it into a step-by-step Instructable.
ShopBot Challenge
ShopBot Challenge
Make It Real Challenge
Arduino Challenge
Arduino Challenge
Be the First to Share
    • Big and Small Contest
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    18 Comments
    WaxF
    WaxF
    6 years ago
    laser cut? seems much easier than inmoov's hand
    neuman.frank
    neuman.frank
    8 years ago on Introduction
    please can you send me the code you used for the second arduino? The one with the vibratory motor and the FSR. bobneuman@gmail.com
    Thanks
    macgyver603
    macgyver603
    The code can be found on my full instructable regarding this project:
    https://www.instructables.com/id/How-to-Build-a-Robotic-Hand-with-Haptic-Feedback/step7/Program-the-Hand/
    macgyver603
    macgyver603
    I used Autodesk Inventor for this project. It had a nice simulation feature that allowed me to play with the design and see exactly how the fingers would move before I went about building them.
    Nishant Das
    Nishant Das
    can you please tell me about the connections you have made
    macgyver603
    macgyver603
    Autodesk Inventor is one of the free downloads for students, so I was able to get my copy for free. I do not know how much it is otherwise.
    http://www.autodesk.com/education/free-software
    varora1
    varora1
    any chance ?? to get the circuit and block diagrams for wiring.. for this cool hand.. !!
    lean04
    lean04
    10 years ago on Introduction
    awesome, this could be used for remote surgery!!, it would provide sensibility to the surgeon.
    Keep it up!
    cShellPro
    cShellPro
    11 years ago on Introduction
    This is a very interesting project.
    Looking forward to your step-by-step
    instructable. Well done!
    mr fat
    mr fat
    Very very cool project! I look forward to seeing what else you build!
    macgyver603
    macgyver603
    Reply 11 years ago on Introduction
    Thanks! I will be rebuilding the hand sometime soon, so I will be able to get pictures of the build process and make a step-by-step Instructable.
    biomech75
    biomech75
    Thnak you! and yes I am working on something now;)
