Arduino Says: Hello World!
Intro: Arduino Says: Hello World!
In this instructable i will show you how to make arduino say ,,Hello world!''. If you are lazy then just watch the video, or read further.
For more instructables or videos Please subscribe me on youtube:
https://www.youtube.com/channel/UCvyN6IevfujPzO4q6...
And support me on patreon:
https://www.patreon.com/TestasTChannel
STEP 1: Things You'l Need
- Arduino UNO
- Some jumper wires
- LCD screen
- Pin headers to solder to LCD pins or just wires.(your choice)
- 10k ohm potentiometer
- 200-300ohm resistor
- Breadboard
STEP 2: The Circuit
To connect your LCD to arduino follow these steps:
- Connect LCD RS pin to arduino pin 12
Connect LCD Enable pin to arduino pin 11
Connect LCD D4 pin to arduino pin 5
Connect LCD D5 pin to arduino pin 4
Connect LCD D6 pin to arduino pin 3
Connect LCD D7 pin to arduino pin 2
- Connect 10k ohm potentiometer to +5V and GND, with it's wiper to LCD screen VO pin (a.k.a. pin 3)
- Connect 200-300ohm resistor to +5V and LCD backlight 15 or 16pin
STEP 3: Software
You can find code in arduino program. Go to File>Examples>LiquidCrystal>HelloWorld. Or just copy this:
LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display. The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
* LCD VSS pin to ground
* LCD VCC pin to 5V
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
/ include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
void loop() {
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis() / 1000);
5 Comments
confeder8.international 3 years ago
Testas.T 3 years ago
JamilA16 7 years ago
Thanks for share !
http://amigosdaprosperidade.com.br
JRV31 7 years ago
Your #include statement is blank. This is the fault of the Instructables editor.
It should read #include "LiquidCrystal.h"
Always proofread code after copying it in. This is just one of the mistakes the editor makes when copying code, there are others.
Nice instructable otherwise.
Testas.T 7 years ago
