Introduction: (LED With Switch) Arduino Simulation Using Tinkercad Circuit
Therefore, we will introduce the basic system of Arduino and Tinkercad.
Then, you will build a LED with a switch by using Tinkercad circuit.
Step 1: List of Components
The figure above shows the diagram of the circuit
List of Components
Arduino Uno R3 X 1
LED (red) X1
Resistors (1k ohm) X 2
Pushbutton X 1
Jumper wire X7
Step 2: Build the Circuit
These are the steps to build the LED with switch circuit.
Reminder
>>Current flows in one direction( the same row) in the breadboard.
Doubts
1. Why my LED can't switch On?
-You need to remove the existing code in the CODE(block) section to create a new one. (You may refer to the steps for Simulation) on the following steps.
OR
-Your connection of the components to the arduino is wrong.(Please refer the steps for building the circuit)
Still have problems, please watch the video to clear your doubts!
Step 3: Steps for Simulation
These are the steps for Simulation and the code blocks.
Reminder
>>You need to create the variable for the Pushbutton (switch) for to code to ensure the buttons tate is included and able to run the code.
What is the variable of the Pushbutton (switch)?
To make it easier, just put buttonState. (You may create another name)
