Introduction: Arduino - TM1637 7 Segment Display & DHT11 Temp Sensor
About: Hello world! I make simple & Advanced projects for people who want to learn programming and electronics. Most of my Instructables are about arduino and the wide range of sensors you can use with it. I make…
Hello world! Today i made a simple Temperature & Humidity Meter with the TM1637 7 Segment Display & DHT11 temp sensor. Follow the next step for the Schematic, Code & Parts list.
This is very easy to build, I made it because i have no temperature meter at the attic. SO a simple cheap option is to build this simple device with arduino.
Step 1: Schematic, Code & Parts List.
Simply wire it up as the Schematic shows, and upload the code.
Make sure you have the below Libraries installed, i attached them to download.
  • #include "dht.h"
  • #include "TM1637.h"
Parts list.
  1. Arduino uno, I used the RobotDyn Uno. (has 8 analog pins)
  2. TM1637 7 Segment 4 Digit Display.
  3. DHT11 KY-015 Temperature sensor.
  4. Jumper wires Set MM/MF/FF
Good luck! Follow me for more!
