Introduction: Arduino-Tamagotchi Project (I Am the Tamagotchi)
I was bored in quarantine and decided to make an Arduino Tamagotchi. Because I hate a lot of animals I choose myself as the Tamagotchi. First I build my console on a breadboard. The wiring is very simple. There are just three buttons, a buzzer and a Nokia 5110 LCD.
Step 1: Building the Project on a Breadboard
I choose the digital pins 2, 3, and 4 for the buttons and 5 for the
buzzer. I decided to place a 47 Ohm resistor between the speaker and the pin, because of the buzzers annoying noice.The Nokia LCD is connected to 8, 9, 10, 11 and 12. After the wiring I started programming, which was most of the work.
Step 2: Programming
Programming took more than two weeks and ended up in a real mess - but it woks fine. I would recommend you to do not make a lot of changes in the programm, because it is half german half english and a bit confusing. In the first lines are the most important information, like button pins and LCD contrast. I think this is helpful. I designed all the graphics with paint and used LCDAssistant to convert the pictures into hex.
I added hunger , fun and tiredness. Half hourly there is a 75 % chance that one status drops. You can fill up the status bars via eating food, playing games or going to bed.
I added a rar file (Tama2.rar) and two separate files (Graphic.c & Tama2.ino). You can choose between one of these options. :)
Step 3: Designing a Circuit Board
After I finished programming I designed a circuit board with Eagle. Because of its small size I choosed an Arduino Mini as the Brain of my game console. The boards size is only 93,4mm x 49,25mm (3,67 x 1,94 inch). I used the service of JLCPCB for my circuit boards. The Arduino Minis lower clock rate (8 MHz) made the games very easy and slow, so I adjusted the speed. Also I changed the buzzer to a smaller one.
Step 4: Adding a Battery
To make the Tamagotchi handheld I used an old battery and a charging module. The battery is from a mobile phone and provides energie for more than three days. The charging module is the 18650 USB Lithium Battery Charging Board. It can charge the battery in a few hours.
Step 5: Designing and Printing a Case
Finally I used a 3D-Printer to build a case for my Tamagotchi. I designed all the CAD-Files in Thinkercad and after a few failed prints I got a good and solid case. I screw everything together and the project was finished.
That's my project. If you have any questions just write a comment down below. :)
