Arduino Tetris
Intro: Arduino Tetris
gather the folowing items
STEP 1: Setting Up the Oled Screen
first download the folowing file https://drive.google.com/file/d/1qkexPET5MUICAarGO...
in this file there are 2 size screens take the one that you have bought. and add the files adafruit_GFX and adafruit_SSD1306 to your libraries. after that run the exampel in the file where you got the libraries to test if the screen works(use the set up form the photo). if not look at https://www.adafruit.com/product/2719 or https://learn.adafruit.com/adafruit-gfx-graphics-l... for help.
STEP 2: Doing the Wiring
once this proces is done you need to wire it all right up. you can keep the oled wired as is. and then use the set up in the picture. and if ur using a AD Analog Keyboard Module then wire it the same like the 3 cables coming from the button setup
STEP 3: The Code
us the code below and make sure u get al the lebraries installed it says it needs when you run it. and if you want help with creating shapes and other things use one of the previusly linked sites.
#include
#define OLED_ADDRESS 0x3C //you may need to change this, this is the OLED I2C address. #define OLED_COMMAND 0x80 #define OLED_DATA 0x40 #define OLED_DISPLAY_OFF 0xAE #define OLED_DISPLAY_ON 0xAF #define OLED_NORMAL_DISPLAY 0xA6 #define OLED_INVERSE_DISPLAY 0xA7 #define OLED_SET_BRIGHTNESS 0x81 #define OLED_SET_ADDRESSING 0x20 #define OLED_HORIZONTAL_ADDRESSING 0x00 #define OLED_VERTICAL_ADDRESSING 0x01 #define OLED_PAGE_ADDRESSING 0x02
#define OLED_SET_COLUMN 0x21 #define OLED_SET_PAGE 0x22
#define KEYPAD_PIN A0
const bool BlockI[4][4] = { { 0, 1, 0, 0 },{ 0, 1, 0, 0 },{ 0, 1, 0, 0 },{ 0, 1, 0, 0 }, }; const bool BlockJ[4][4] = { { 0, 1, 0, 0 },{ 0, 1, 0, 0 },{ 1, 1, 0, 0 },{ 0, 0, 0, 0 }, }; const bool BlockL[4][4] = { { 0, 1, 0, 0 },{ 0, 1, 0, 0 },{ 0, 1, 1, 0 },{ 0, 0, 0, 0 }, }; const bool BlockO[4][4] = { { 0, 0, 0, 0 },{ 0, 1, 1, 0 },{ 0, 1, 1, 0 },{ 0, 0, 0, 0 }, }; const bool BlockS[4][4] = { { 0, 0, 0, 0 },{ 0, 1, 1, 0 },{ 1, 1, 0, 0 },{ 0, 0, 0, 0 }, }; const bool BlockT[4][4] = { { 0, 0, 0, 0 },{ 1, 1, 1, 0 },{ 0, 1, 0, 0 },{ 0, 0, 0, 0 }, }; const bool BlockZ[4][4] = { { 0, 0, 0, 0 },{ 1, 1, 0, 0 },{ 0, 1, 1, 0 },{ 0, 0, 0, 0 }, };
const byte NumberFont[10][8] PROGMEM = {
{ 0x00, 0x1c, 0x22, 0x26, 0x2a, 0x32, 0x22, 0x1c }, { 0x00, 0x1c, 0x08, 0x08, 0x08, 0x08, 0x0c, 0x08 }, { 0x00, 0x3e, 0x02, 0x04, 0x18, 0x20, 0x22, 0x1c }, { 0x00, 0x1c, 0x22, 0x20, 0x18, 0x20, 0x22, 0x1c }, { 0x00, 0x10, 0x10, 0x3e, 0x12, 0x14, 0x18, 0x10 }, { 0x00, 0x1c, 0x22, 0x20, 0x20, 0x1e, 0x02, 0x3e }, { 0x00, 0x1c, 0x22, 0x22, 0x1e, 0x02, 0x04, 0x18 }, { 0x00, 0x04, 0x04, 0x04, 0x08, 0x10, 0x20, 0x3e }, { 0x00, 0x1c, 0x22, 0x22, 0x1c, 0x22, 0x22, 0x1c }, { 0x00, 0x0c, 0x10, 0x20, 0x3c, 0x22, 0x22, 0x1c } };
#define KEY_LEFT 1 #define KEY_RIGHT 2 #define KEY_DOWN 3 #define KEY_ROTATE 4
byte uiKeyLeft = 2; byte uiKeyRight = 3; byte uiKeyDown = 4; byte uiKeyRotate = 5;
struct keyPress { long left; long right; long down; long rotate; };
struct PieceSpace { byte umBlock[4][4]; char Row; char Coloum; };
byte pageArray[8] = { 0 }; byte scoreDisplayBuffer[8][6] = { { 0 },{ 0 } }; byte nextBlockBuffer[8][2] = { { 0 },{ 0 } }; bool optomizePageArray[8] = { 0 }; byte blockColoum[10] = { 0 }; byte tetrisScreen[14][25] = { { 1 } ,{ 1 } }; PieceSpace currentPiece = { 0 }; PieceSpace oldPiece = { 0 }; byte nextPiece = 0; keyPress key = { 0 }; bool gameOver = false; unsigned long moveTime = 0; int pageStart = 0; int pageEnd = 0;
int score = 0; int acceleration = 0; int level = 0; int levellineCount = 0; int dropDelay = 1000;
// I2C
void OLEDCommand(byte command) {
Wire.beginTransmission(OLED_ADDRESS); Wire.write(OLED_COMMAND); Wire.write(command); Wire.endTransmission(); }
void OLEDData(byte data) {
Wire.beginTransmission(OLED_ADDRESS); Wire.write(OLED_DATA); Wire.write(data); Wire.endTransmission();
void setup() { Serial.begin(9600); while (!Serial) { ; }
Wire.begin(); Wire.setClock(400000);
OLEDCommand(OLED_DISPLAY_OFF); delay(20); OLEDCommand(OLED_DISPLAY_ON); delay(20); OLEDCommand(OLED_NORMAL_DISPLAY); delay(20); OLEDCommand(0x8D); delay(20); OLEDCommand(0x14); delay(20); OLEDCommand(OLED_NORMAL_DISPLAY);
fillTetrisScreen(0);
randomSeed(analogRead(7)); /// To do: create a decent random number generator.
pinMode(13, OUTPUT); digitalWrite(13, HIGH); delay(100); digitalWrite(13, LOW); delay(200); digitalWrite(13, HIGH); delay(50); digitalWrite(13, LOW); }
void fillTetrisArray(byte value)
{ for (char r = 0; r < 24; r++) { for (char c = 0; c < 14; c++)
{ tetrisScreen[c][r] = value; } }
for (char r = 21; r < 24; r++) for (char c = 0; c < 14; c++) tetrisScreen[c][r] = 0; }
void fillTetrisScreen(byte value)
{ for (int r = 1; r < 21; r++) { for (int c = 2; c < 12; c++)
{ tetrisScreen[c][r] = value; } } }
void drawTetrisScreen() {
for (byte r = 1; r < 21; r++)
{ //loop through rows to see if there is data to be sent
for (byte c = 2; c < 12; c++)
if ((tetrisScreen[c][r] == 2) | (tetrisScreen[c][r] == 3))
{ //send line to screen for (byte i = 0; i < 10; i++)/// i=2 i<12!!
{ blockColoum[i] = tetrisScreen[i + 2][r];
//clear delete block if (tetrisScreen[i + 2][r] == 3) tetrisScreen[i + 2][r] = 0;
} drawTetrisLine((r - 1) * 6); break; break; }
void drawTetrisLine(byte x)
{ //fill array with blocks based on blockRow
//clear page and Optimize array memset(optomizePageArray, 0, 8); ///review this... declare them here? interesting question... memset(pageArray, 0, 8);
x++; // up one
//*********Column 0***********
//draw block if (blockColoum[0] == 2 | blockColoum[0] == 1) { pageArray[0] = pageArray[0] | B11111001; optomizePageArray[0] = 1;
//delete block if (blockColoum[0] == 3) { pageArray[0] = pageArray[0] | B00000001; //create side wall pageArray[0] = pageArray[0] & B00000111; optomizePageArray[0] = 1; }
//*********Column 1*********** if (blockColoum[1] == 2 | blockColoum[1] == 1) { pageArray[1] = pageArray[1] | B00111110; optomizePageArray[1] = 1; }
//delete block if (blockColoum[1] == 3) { pageArray[1] = pageArray[1] & B11000001; optomizePageArray[1] = 1; }
//*********Column 2*********** if (blockColoum[2] == 2 | blockColoum[2] == 1) { pageArray[1] = pageArray[1] | B10000000; optomizePageArray[1] = 1;
pageArray[2] = pageArray[2] | B00001111; optomizePageArray[2] = 1;
//delete block if (blockColoum[2] == 3) { pageArray[1] = pageArray[1] & B01111111; optomizePageArray[1] = 1;
pageArray[2] = pageArray[2] & B11110000; optomizePageArray[2] = 1;
//*********Column 3*********** if (blockColoum[3] == 2 | blockColoum[3] == 1) { pageArray[2] = pageArray[2] | B11100000; optomizePageArray[2] = 1;
pageArray[3] = pageArray[3] | B00000011; optomizePageArray[3] = 1;
//delete block if (blockColoum[3] == 3) { pageArray[2] = pageArray[2] & B00011111; optomizePageArray[2] = 1;
pageArray[3] = pageArray[3] & B11111100; optomizePageArray[3] = 1;
//*********Column 4*********** if (blockColoum[4] == 2 | blockColoum[4] == 1) { pageArray[3] = pageArray[3] | B11111000; optomizePageArray[3] = 1;
} //delete block if (blockColoum[4] == 3) { pageArray[3] = pageArray[3] & B00000111; optomizePageArray[3] = 1;
//*********Column 5***********
if (blockColoum[5] == 2 | blockColoum[5] == 1) { pageArray[4] = pageArray[4] | B00111110; optomizePageArray[4] = 1;
//delete block if (blockColoum[5] == 3) { pageArray[4] = pageArray[4] & B11000001; optomizePageArray[4] = 1;
//*********Column 6*********** if (blockColoum[6] == 2 | blockColoum[6] == 1) { pageArray[4] = pageArray[4] | B10000000; optomizePageArray[4] = 1;
pageArray[5] = pageArray[5] | B00001111; optomizePageArray[5] = 1;
} //delete block if (blockColoum[6] == 3) { pageArray[4] = pageArray[4] & B01111111; optomizePageArray[4] = 1;
pageArray[5] = pageArray[5] & B11110000; optomizePageArray[5] = 1;
//*********Column 7*********** if (blockColoum[7] == 2 | blockColoum[7] == 1) { pageArray[5] = pageArray[5] | B11100000; optomizePageArray[5] = 1;
pageArray[6] = pageArray[6] | B00000011; optomizePageArray[6] = 1;
if (blockColoum[7] == 3) { pageArray[5] = pageArray[5] & B00011111; optomizePageArray[5] = 1;
pageArray[6] = pageArray[6] & B11111100; optomizePageArray[6] = 1;
//*********Column 8*********** if (blockColoum[8] == 2 | blockColoum[8] == 1) { pageArray[6] = pageArray[6] | B11111000; optomizePageArray[6] = 1;
//delete block if (blockColoum[8] == 3) { pageArray[6] = pageArray[6] & B00000111; optomizePageArray[6] = 1;
//*********Column 9*********** if (blockColoum[9] == 2 | blockColoum[9] == 1) { pageArray[7] = pageArray[7] | B10111110; optomizePageArray[7] = 1; }
if (blockColoum[9] == 3) { pageArray[7] = pageArray[7] | B10000000;//create side wall pageArray[7] = pageArray[7] & B11000001; optomizePageArray[7] = 1; }
//Optimize - figure out what page array has data
for (int page = 0; page < 8; page++)
{ if (optomizePageArray[page]) { //block found set page start pageStart = page; break; }
} for (int page = 7; page >= 0; page--)
{ if (optomizePageArray[page]) { //block found set page end pageEnd = page; break; }
//set Vertical addressing mode and column - page start end OLEDCommand(OLED_SET_ADDRESSING); OLEDCommand(OLED_VERTICAL_ADDRESSING);
OLEDCommand(OLED_SET_COLUMN); OLEDCommand(x); OLEDCommand(x + 4);
OLEDCommand(OLED_SET_PAGE); OLEDCommand(pageStart); OLEDCommand(pageEnd);
//send the array 5 times
for (int c = 0; c <5; c++) { for (int p = pageStart; p <= pageEnd; p++) { OLEDData(pageArray[p]); }
void loadPiece(byte peiceNumber, byte row, byte coloum, bool loadScreen)
{ //load the piece from piece array to screen byte pieceRow = 0; byte pieceColoum = 0; byte c = 0;
switch (peiceNumber) { case 1: memcpy(currentPiece.umBlock, BlockI, 16); break; case 2: memcpy(currentPiece.umBlock, BlockJ, 16); break; case 3: memcpy(currentPiece.umBlock, BlockL, 16); break; case 4: memcpy(currentPiece.umBlock, BlockO, 16); break; case 5: memcpy(currentPiece.umBlock, BlockS, 16); break; case 6: memcpy(currentPiece.umBlock, BlockT, 16); break; case 7: memcpy(currentPiece.umBlock, BlockZ, 16); break; }
currentPiece.Row = row; currentPiece.Coloum = coloum;
if (loadScreen) {
oldPiece = currentPiece;
for (c = coloum; c < coloum + 4; c++) { for (int r = row; r < row + 4; r++) { if (currentPiece.umBlock[pieceColoum][pieceRow]) tetrisScreen[c][r] = 2; pieceRow++; } pieceRow = 0; pieceColoum++; } }
void drawPiece()
char coloum; char row; byte pieceRow = 0; byte pieceColoum = 0; char c = 0;
// delete blocks first
coloum = oldPiece.Coloum; row = oldPiece.Row;
for (c = coloum; c < coloum + 4; c++) { for (char r = row; r < row + 4; r++) { if (oldPiece.umBlock[pieceColoum][pieceRow]) tetrisScreen[c][r] = 3; pieceRow++; } pieceRow = 0; pieceColoum++; }
//draw new blocks pieceRow = 0; pieceColoum = 0; c = 0;
coloum = currentPiece.Coloum; row = currentPiece.Row;
for (c = coloum; c < coloum + 4; c++) { for (char r = row; r < row + 4; r++) { if (currentPiece.umBlock[pieceColoum][pieceRow]) tetrisScreen[c][r] = 2; pieceRow++; } pieceRow = 0; pieceColoum++; } }
void drawLandedPiece()
// Landed pieces are 1
for (c = coloum; c < coloum + 4; c++) { for (int r = row; r < row + 4; r++) { if (currentPiece.umBlock[pieceColoum][pieceRow]) tetrisScreen[c][r] = 1; pieceRow++; } pieceRow = 0; pieceColoum++; }
processCompletedLines(); }
bool led = true;
void RotatePiece() { byte i, j;
byte umFig[4][4] = { 0 };
memcpy(oldPiece.umBlock, currentPiece.umBlock, 16); oldPiece.Row = currentPiece.Row; oldPiece.Coloum = currentPiece.Coloum;
for (i = 0; i < 4; ++i) for (j = 0; j < 4; ++j) umFig[j][i] = currentPiece.umBlock[4 - i - 1][j];
oldPiece = currentPiece; memcpy(currentPiece.umBlock, umFig, 16);
if (checkColloision()) currentPiece = oldPiece;
// no need for this... if (led) { digitalWrite(13, HIGH); led = false; } delay(1); digitalWrite(13, LOW); if (led == false) { digitalWrite(13, LOW); led = true; }
bool movePieceDown() { bool pieceLanded = false; char rndPiece = 0;
currentPiece.Row = currentPiece.Row - 1;
//check collision
if (checkColloision()) {
// its at the bottom make it a landed piece and start new piece currentPiece = oldPiece; // back to where it was drawLandedPiece(); pieceLanded = true;
} if (pieceLanded)
loadPiece(nextPiece, 19, 4, false); acceleration = 0;
if (checkColloision()) gameOver = true; else {
loadPiece(nextPiece, 19, 4, true); acceleration = 0;//reset acceleration as there is a new piece }
nextPiece = random(1, 7); setNextBlock(nextPiece);
void movePieceLeft() {
currentPiece.Coloum = currentPiece.Coloum - 1;
//check collision
if (checkColloision()) currentPiece = oldPiece; // back to where it was }
void movePieceRight() {
currentPiece.Coloum = currentPiece.Coloum + 1;
//check collision
bool checkColloision() {
byte pieceRow = 0; byte pieceColoum = 0; char c = 0; char coloum = currentPiece.Coloum; char row = currentPiece.Row;
//scan across piece and translate to Tetris array and check Collisions.
for (c = coloum; c < coloum + 4; c++) { for (char r = row; r < row + 4; r++) { if (currentPiece.umBlock[pieceColoum][pieceRow]) {
if (tetrisScreen[c][r] == 1) return true; //is it on landed blocks?
} pieceRow++; }
return false;
void processCompletedLines() {
char rowCheck = 0; char coloumCheck = 0; bool fullLine = false; bool noLine = true; char linesProcessed = 0; char clearedLines = 0; char topRow = 0; char bottomRow = 0; char currentRow = 0; int amountScored = 0;
if (currentPiece.Row < 1)bottomRow = 1; else bottomRow = currentPiece.Row;
for (int rowCheck = bottomRow; rowCheck < currentPiece.Row + 4; rowCheck++)
bool fullLine = true;
for (coloumCheck = 2; coloumCheck < 12; coloumCheck++) { if (tetrisScreen[coloumCheck][rowCheck] == 0) { fullLine = false; break; } }
if (fullLine) { //make line values 3's and render for (char c = 2; c < 12; c++) tetrisScreen[c][rowCheck] = 3;
bottomRow = rowCheck + 1; //line is now all 0's linesProcessed++;
delay(77); // animation :)
drawTetrisScreen();
//******all lines are 0's and have been removed from the screen
if (linesProcessed)
clearedLines = linesProcessed;
while (clearedLines) {
for (currentRow = 1; currentRow < 20; currentRow++) { noLine = true; for (char c = 2; c < 12; c++) { if (tetrisScreen[c][currentRow]) noLine = false; } if (noLine) { //move all lines down
for (int r = currentRow + 1; r < 20; r++) { for (char c = 2; c < 12; c++) {
if (tetrisScreen[c][r]) tetrisScreen[c][r - 1] = 2; else tetrisScreen[c][r - 1] = 3; }
//make the 2's 1's for (char r = 1; r < 24; r++) { for (char c = 2; c < 12; c++) {
if (tetrisScreen[c][r] == 2)tetrisScreen[c][r] = 1; } } clearedLines--; drawTetrisScreen(); } }
// ************** process score ******************* switch (linesProcessed) { case 1: amountScored = 40 * (level + 1); break; case 2: amountScored = 100 * (level + 1); break; case 3: amountScored = 300 * (level + 1); break; case 4: amountScored = 1200 * (level + 1);
//do 4 line affect
OLEDCommand(OLED_INVERSE_DISPLAY); delay(100); OLEDCommand(OLED_NORMAL_DISPLAY);
break; }
//score animation for (long s = score; s < score + amountScored; s = s + (1 * (level+1))) setScore(s, false);
score = score + amountScored; setScore(score, false);
//****update level line count
levellineCount = levellineCount + linesProcessed; if (levellineCount > 10) { level++; levellineCount = 0;
//do level up affect
OLEDCommand(OLED_INVERSE_DISPLAY); delay(100); OLEDCommand(OLED_NORMAL_DISPLAY); delay(100); OLEDCommand(OLED_INVERSE_DISPLAY); delay(100); OLEDCommand(OLED_NORMAL_DISPLAY);
//make the 2's 1's
for (char r = bottomRow; r <= topRow; r++) {
for (char c = 2; c < 12; c++) { if (tetrisScreen[c][r]) tetrisScreen[c][r] = 1;
void tetrisScreenToSerial()
{ //for debug for (int r = 0; r < 24; r++) { for (int c = 0; c < 14; c++) { Serial.print(tetrisScreen[c][r], DEC); }
Serial.println();
Serial.println();
long keytimer = 0; bool processKey = true; int Debounce = 0;
bool processKeys()
{ // not happy with this, To do: sort this out and get the movment right!
char uiKeyCode = 0; bool keypressed = true; int leftRight = 300 - acceleration; int rotate = 700; int down = 110 - acceleration; int analogKey = analogRead(KEYPAD_PIN);
if ((analogKey > -1) && (analogKey < 5)) {
Debounce++;
if (Debounce > 10) {
if (processKey) {
uiKeyCode = KEY_LEFT; //key will be processed immediately key.left = millis();
if (millis() < key.left + leftRight) processKey = false; else { processKey = true; acceleration = acceleration + 70; if (acceleration > leftRight) acceleration = leftRight; }
else if ((analogKey < 510) && (analogKey > 500)) {
Debounce++;
if (processKey) {
uiKeyCode = KEY_RIGHT; //key will be processed immediately key.right = millis();
if (millis() < key.right + leftRight) processKey = false; else { processKey = true; acceleration = acceleration + 70; if (acceleration > leftRight) acceleration = leftRight; }
else if ((analogKey < 330) && (analogKey > 324)) {
Debounce++;
if (processKey) {
uiKeyCode = KEY_DOWN; //key will be processed immediately key.down = millis();
if (millis() < key.down + down) processKey = false; else { processKey = true; acceleration = acceleration + 40; if (acceleration > down) acceleration = down;
else if ((analogKey < 745) && (analogKey > 735)) {
Debounce++;
if (processKey) {
uiKeyCode = KEY_ROTATE; //key will be processed immediately key.rotate = millis();
if (millis() < key.rotate + rotate) processKey = false; else processKey = true; }
else { acceleration = 0; processKey = true; Debounce = 0; }
switch (uiKeyCode) { case KEY_LEFT: movePieceLeft(); break; case KEY_RIGHT: movePieceRight(); break; case KEY_DOWN: movePieceDown(); break; case KEY_ROTATE: RotatePiece(); break; default: keypressed = false; break; }
if (keypressed) { drawPiece(); drawTetrisScreen(); } }
void setScore(long score, bool blank)
{ // this is a kludge. To do: create a proper system for rendering numbers and letters. long ones = (score % 10); long tens = ((score / 10) % 10); long hundreds = ((score / 100) % 10); long thousands = ((score / 1000) % 10); long tenthousands = ((score / 10000) % 10); long hunderedthousands = ((score / 100000) % 10);
//Serial.println(ones); //Serial.println(tens); //Serial.println(hundreds); //Serial.println(thousands); //Serial.println(tenthousands); //Serial.println(hunderedthousands);
//create the score in upper left part of the screen byte font = 0; char bytes_out[8]; memset(scoreDisplayBuffer, 0, sizeof scoreDisplayBuffer);
//****************score digit 6****************
for (int v = 0; v<8; v++) bytes_out[v] = pgm_read_byte(&NumberFont[hunderedthousands][v]);
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][0] = scoreDisplayBuffer[i][0] | bytes_out[i] >> 1; }
//****************score digit 5****************
for (int v = 0; v<8; v++) bytes_out[v] = pgm_read_byte(&NumberFont[tenthousands][v]);
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][0] = scoreDisplayBuffer[i][0] | (bytes_out[i] << 6); }
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][1] = scoreDisplayBuffer[i][1] | bytes_out[i] >> 1; }
//****************score digit 4****************
for (int v = 0; v<8; v++) bytes_out[v] = pgm_read_byte(&NumberFont[thousands][v]);
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][1] = scoreDisplayBuffer[i][1] | (bytes_out[i] << 6); }
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][2] = scoreDisplayBuffer[i][2] | bytes_out[i] >> 1; }
//****************score digit 3****************
for (int v = 0; v<8; v++) bytes_out[v] = pgm_read_byte(&NumberFont[hundreds][v]);
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][2] = scoreDisplayBuffer[i][2] | (bytes_out[i] << 6); }
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][3] = scoreDisplayBuffer[i][3] | bytes_out[i] >> 1; }
//****************score digit 2****************
for (int v = 0; v<8; v++) bytes_out[v] = pgm_read_byte(&NumberFont[tens][v]);
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][3] = scoreDisplayBuffer[i][3] | (bytes_out[i] << 6); }
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][4] = scoreDisplayBuffer[i][4] | bytes_out[i] >> 1; }
//****************score digit 1****************
for (int v = 0; v<8; v++) bytes_out[v] = pgm_read_byte(&NumberFont[ones][v]);
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][4] = scoreDisplayBuffer[i][4] | (bytes_out[i] << 6); }
//write the number to the Score buffer for (int i = 0; i < 8; i++) { scoreDisplayBuffer[i][5] = scoreDisplayBuffer[i][5] | bytes_out[i] >> 1;
OLEDCommand(OLED_SET_COLUMN); OLEDCommand(120); //Set column start OLEDCommand(127); //Set column end
OLEDCommand(OLED_SET_PAGE); OLEDCommand(0); //Set page start OLEDCommand(5); //Set page end
for (int p = 0; p < 8; p++) { for (int c = 0; c <6; c++) { if (blank) OLEDData(0); else OLEDData(scoreDisplayBuffer[p][c]); }
void setNextBlock(byte peiceNumber)
{ memset(nextBlockBuffer, 0, sizeof nextBlockBuffer); //clear buffer switch (peiceNumber) { case 1:
//************l piece - 1 ************* for (int k = 2; k < 6; k++) { nextBlockBuffer[k][0] = B01110111; nextBlockBuffer[k][1] = B01110111; }
break;
case 2:
//************J piece - 2 ************* for (int k = 0; k < 3; k++) { nextBlockBuffer[k][0] = B01110000; nextBlockBuffer[k][1] = B01110111; }
for (int k = 4; k < 7; k++) { nextBlockBuffer[k][0] = B01110000; } break; case 3: //************L piece - 3 ************* for (int k = 0; k < 3; k++) { nextBlockBuffer[k][0] = B01110000; }
for (int k = 4; k < 7; k++) { nextBlockBuffer[k][0] = B01110000; nextBlockBuffer[k][1] = B01110111; }
break;
case 4:
//************O piece - 4 ************* for (int k = 0; k < 3; k++) { nextBlockBuffer[k][0] = B01110000; nextBlockBuffer[k][1] = B00000111; }
for (int k = 4; k < 7; k++) { nextBlockBuffer[k][0] = B01110000; nextBlockBuffer[k][1] = B00000111; }
break;
case 5:
//************S piece - 5 ************* for (int k = 0; k < 3; k++) { nextBlockBuffer[k][0] = B01110000; nextBlockBuffer[k][1] = B00000111; }
for (int k = 4; k < 7; k++) { nextBlockBuffer[k][0] = B00000000; nextBlockBuffer[k][1] = B11101110; }
break;
case 6:
//************T piece - 6 ************* for (int k = 0; k < 3; k++) { nextBlockBuffer[k][0] = B01110000; nextBlockBuffer[k][1] = B01110111; }
for (int k = 4; k < 7; k++) { nextBlockBuffer[k][0] = B00000000; nextBlockBuffer[k][1] = B00001110; }
break;
case 7:
//************Z piece - 7 ************* for (int k = 0; k < 3; k++) { nextBlockBuffer[k][0] = B01110000; nextBlockBuffer[k][1] = B00000111; }
for (int k = 4; k < 7; k++) { nextBlockBuffer[k][0] = B11101110; nextBlockBuffer[k][1] = B00000000; }
break; }
OLEDCommand(OLED_SET_PAGE); OLEDCommand(6); //Set page start OLEDCommand(7); //Set page end
for (int p = 0; p < 8; p++) { for (int c = 0; c <2; c++) { OLEDData(nextBlockBuffer[p][c]); }
void drawBottom()
OLEDCommand(OLED_SET_COLUMN); OLEDCommand(0); //Set column start OLEDCommand(0); //Set column end
OLEDCommand(OLED_SET_PAGE); OLEDCommand(0); //Set page start OLEDCommand(7); //Set page end
for (int c = 0; c <8; c++) {
OLEDData(255); } }
void drawSides()
OLEDCommand(OLED_SET_COLUMN); OLEDCommand(0); //Set column start OLEDCommand(127); //Set column end
for (int r = 0; r < 128; r++) {
for (int c = 0; c < 8; c++) { if (c == 0) OLEDData(1); else if (c == 7) OLEDData(128); else OLEDData(0); }
void loop() { //main loop code //To do: create high score system that savees to EEprom gameOver = false; score = 0; fillTetrisArray(1); //fill with 1's to make border fillTetrisScreen(2); drawTetrisScreen(); delay(200); fillTetrisScreen(3); drawTetrisScreen(); delay(200); drawSides(); drawBottom();
tetrisScreenToSerial();
OLEDCommand(OLED_INVERSE_DISPLAY); delay(200); OLEDCommand(OLED_NORMAL_DISPLAY);
loadPiece(random(1, 7), 20, 5, true); drawTetrisScreen(); nextPiece = random(1, 7); setNextBlock(nextPiece);
setScore(0, false); delay(300); setScore(0, true); delay(300); setScore(0, false); byte rnd = 0;
//for (int j = 0; j < 1000000; j++) {
//setScore(j, false);
while (!gameOver)
{ movePieceDown(); drawPiece(); drawTetrisScreen(); moveTime = millis(); while (millis() - moveTime<(dropDelay - (level * 50))) processKeys(); }
Penolopy Bulnick 3 years ago
