Introduction: Arduino Thermometer(7-Segment)
Using a dual 7-segment display, a DS18B20 temperature sensor and a couple of shift registers I figured that I could build a digital thermometer.
Step 1: Temperature Sensor
The sensor I'm using is the DS18B20, it's a 3pin sensor that just requires a single input pin from the arduino. Multiple sensors can be hooked together, however I'm just using one for this project. As with a lot of different sensors there's a handy library that makes it particularly easy to get the temperature in centigrade or fahrenheit, it's the Dallas_Temperature library available here and a spec sheet for the sensor available from maxim.
To connect it to the arduino connect the ground pin on the sensor to a ground pin on the arduino, put a 4.7k resistor between pin 2 and pin 3 on the sensor, connect pin 3 to 3.3v from the arduino and then connect pin 2 to digital input on the arduino. Once this is done, we're ready to read the temperature!
Step 2: Controlling the Display
I chose to use a dual 7-segment , it didn't take long to figure out the pin outs, however an issue was the number of pins this would require from the arduino if I hooked it up directly, a massive 16. With two shift registers hooked up together this could reduce the number of pins required to only 3, as the two shift registers require only 3 pins and with being hooked together provide 16 parallel outputs.
Step 3: Putting It Together
The code I've put together is at the end of this post. It basically sets up the temperature libraries, reads the temp, and then puts this into the shift registers.
#include OneWire.h
#include DallasTemperature.h
// pin setups
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int tempPin = 7;
// librraries for connecting to sensor
OneWire oneWire(tempPin);
DallasTemperature tempSens(&oneWire);
// characters for displaying on 7-seg display 0-9
byte numberSet[10] = {
B01111011, B01000001, B00110111, B01100111, // 0,1,2,3
B01001101, B01101110, B01111110, B01000011, // 4,5,6,7
B01111111, B01101111 // 8,9
void setup() {
// init serial
Serial.begin(9600);
// init temp sensor
tempSens.begin();
// set pin modes for shift registors
pinMode(latchPin, OUTPUT);
pinMode(myClockPin, OUTPUT);
pinMode(myDataPin, OUTPUT);
void loop() {
tempSens.requestTemperatures();
float t = tempSens.getTempCByIndex(0);
Serial.println(t);
// cast to float (only have 2 digits to use on display)
int rT = (int)t;
// get units of temp
int units = rT % 10;
// get tens value of temp
rT = rT/10;
int tens = rT % 10;
displayNumb(units, tens);
delay(100);
void displayNumb(int a, int b) {
// get the code for the numbers
byte bitsA = numberSet[a];
byte bitsB = numberSet[b];
// set ready to shift out
digitalWrite(latchPin, LOW);
// shift units
shiftOut(dataPin, clockPin, bitsA);
// shift tens
shiftOut(dataPin, clockPin, bitsB);
// shift out data
digitalWrite(latchPin, HIGH);
// shift the data out to the shift registors
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) {
int i=0;
int pinState;
digitalWrite(myDataPin, 0);
digitalWrite(myClockPin, 0);
// iterate over each bit in the myDataOut byte
for (i=7; i>=0; i--) {
if ( myDataOut & (1< pinState= 1;
else {
pinState= 0;
digitalWrite(myDataPin, pinState);
digitalWrite(myClockPin, 1);
#include OneWire.h
// pin setups
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
int tempPin = 7;
void setup() {
// init serial
Serial.begin(9600);
// init temp sensor
tempSens.begin();
void loop() {
Serial.println(t);
int rT = (int)t;
rT = rT/10;
int tens = rT % 10;
delay(100);
// shift units
// shift tens
// shift out data
int i=0;
int pinState;
else {
pinState= 0;
Step 4: Final Build
The temperature is displayed in the dual 7 segment display.
