Arduino - Turn ON Your LEDs and Lamps With a Clap (Relay and Sound Sensor)
Intro: Arduino - Turn ON Your LEDs and Lamps With a Clap (Relay and Sound Sensor)
In this tutorial we will learn how to control the Arduino Sound Sensor. So we will control our LEDs and Lamps with a clap. We will use a sound sensor and a relay module for this.
STEP 1: Required Hardware
Arduino Board - https://goo.gl/Rqc5w2
Relay Module - https://goo.gl/yAxcPL
Sound Sensor - https://goo.gl/2pXWsw
LED Strip 5M - https://goo.gl/2pXWsw
LED Adapter - https://goo.gl/2pXWsw
9V Battery - https://goo.gl/2pXWsw
F to F Jumper - https://goo.gl/2pXWsw
M to M Jumper - https://goo.gl/2pXWsw
Breadboard - https://goo.gl/2pXWsw
Battery Cable - https://goo.gl/2pXWsw
Some Promotion Links
Flash Deals -- https://goo.gl/CVqg7P
Mega Stock Clearance -- https://goo.gl/eCbuiP
Arduino Kits -- https://goo.gl/uwr19e
More Budget 3D Printers -- https://goo.gl/uwr19e
Anet A8 3D Printer Promotion -- https://goo.gl/uwr19e
STEP 2: About the Relay Module
5V 1 Channel H/L Level Relay Module
Specification:
Maximum load: AC 250V/10A, DC 30V/10A
Trigger current: 5mA
Working voltage: 5V
Module interface:
VCC: positive power supply
GND: negative power supply (GND)
IN: can be high or low level control relay
Relay outputs:
NO: normally open relay interface
COM: Common Interface Relays
NC: normally closed relay interface
STEP 3: High Voltage Warning
I warning you here that we will use High Voltage which used could result in serious injuries or death.
So must be very carefully! I take no responsibility for any of actions.
STEP 4: About the Sound Sensor
This module allows you to detect when sound has exceeded a set point you select. Sound is detected via a microphone.
The sound level set point is adjusted via an on board potentiometer. When the sound level exceeds the set point, an LED on the module is illuminated and the output is sent low.
Adjust sensitivity of the Sound Sensor
When less sensitive, it takes more sound to trigger the device When more sensitive, it takes less sound to trigger the device
STEP 5: Connections
Connection of the Relay Module and Lamp
The HIGH Voltage part we need a power plug, a socket and a cable with two wires.
One of the two wires will be cut and connected to the common and the normally open pin of the module output connector.
The Relay VCC pin will be connected to the +5V pin of the Arduino.
The Relay GND pin will be connected to the GND pin of the Arduino.
The Relay INPUT pin will be connected to the Digital 5 pin of the Arduino.
Connection of the Sound Sensor
The Sound Sensor VCC pin will be connected to the +5V pin of the Arduino.
The Sound Sensor GND pin will be connected to the GND pin of the Arduino.
The Sound Sensor OUT pin will be connected to the Digital 4 pin of the Arduino.
Connection of the LED Strip and Adapter
The LED strip possitive cable will be connected to the COM input of the Relay.
The Adapter possitive cable will be connected to the NO input of the Relay.
The LED and Adapter ground cable will be connected together.
STEP 6: Source Code
You can copy and paste the code to empty page of the Arduino IDE.
Get the Code - https://goo.gl/0wVN1c
STEP 7: You Can Subscribe to My YouTube Channel
You can subscribe to the my YouTube channel for more tutorials and projects. Subscribe for support. Thank you.
Go to my YouTube Channel - https://goo.gl/f0RHmR
4 Comments
kp358760 3 years ago
And another thins is I can try different codes as well right to do other stuff ?
morris.flohr 4 years ago
JakubZ18 6 years ago
I made it i use this program and its working. :)))))))
sorry for my english i m from other countrie
