Introduction: Arduino UNO Ultrasonic Motion Alarm
How to make arduino powered motion alarm!
I Hope You Enjoy
I Hope You Enjoy
Step 1: Components
Components:
Arduino UNO
Buzzer
Ultrasonic Sensor
Jumper Wire
Arduino UNO
Buzzer
Ultrasonic Sensor
Jumper Wire
Step 2: Uploading the Code
CODE :
#define trigPin 12
#define echoPin 13
int Buzzer = 8;
void setup() {
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(Buzzer, OUTPUT);
void loop() {
int duration, distance;
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance >= 80 || distance Serial.println("no object detected");
digitalWrite(Buzzer, LOW);
else {
Serial.println("object detected");
tone(Buzzer, 400); // play 400 Hz tone for 500 ms
delay(500);
tone(Buzzer, 800); // play 800Hz tone for 500ms
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
noTone(Buzzer);
delay(300);
#define trigPin 12
#define echoPin 13
int Buzzer = 8;
void setup() {
void loop() {
else {
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
noTone(Buzzer);
delay(300);
Step 3: Ultrasonic Sensor Connections
Connections :
Connect Vcc to Vin pin
Connect GND to GND
connect ECHO to Pin 13
connect TRİG to Pin 12
Connect GND to GND
Step 4: Connecting the Buzzer
Connect Positive Terminal To Pin 8
Connect Negative Terminal To GND pin on POWER
Step 5: Finish!!
Now Power Up Arduino And Test It, Don't Forget To Vote, I Hope You Enjoy Thanks For Supporting Goodbye ?
