Arduino Uno Memory Game!
Intro: Arduino Uno Memory Game!
Hey guys!
Here's a quick and easy Arduino memory game!!
Arduino file download here: http://www.mediafire.com/file/qrehasjuqdt17s9/memo...
Or copy and paste this:
Feel free to ask any questions!!
const int LED_YELLOW = 10; // Yellow LED pin
const int LED_BLUE = 11; // Blue LED pin const int LED_GREEN = 12; // Green LED pin const int LED_RED = 13; // Red LED pin
const int BUTTON_YELLOW = 2; // Yellow button input pin const int BUTTON_BLUE = 3; // Blue button input pin const int BUTTON_GREEN = 4; // Green button input pin const int BUTTON_RED = 5; // Red button input pin
const int PIEZO = 6; // The pin the piezo is connected to
const int STATE_START_GAME = 0; // Initial state const int STATE_PICK_RND_SEQUENCE = 1; // Pick a random sequence of LEDs const int STATE_SHOW_RND_SEQUENCE = 2; // Show the randomly selected sequence of LED flashes const int STATE_READ_PLAYER_GUESS = 3; // Read the player's guess const int STATE_VERIFY_GUESS = 4; // Check the guess against the random sequence const int STATE_GUESS_CORRECT = 5; // Player guessed correctly const int STATE_GUESS_INCORRECT = 6; // Player guessed incorrectly
const int MAX_DIFFICULTY_LEVEL = 9; // Maximum difficulty level (LED flash sequence length)
// Array used to store the generated random sequence int randomSequence[MAX_DIFFICULTY_LEVEL];
// Array used to store the player's guess int playerGuess[MAX_DIFFICULTY_LEVEL]; // A counter to record the number of button presses made by the player int numButtonPresses;
// The current state the game is in int currentState; int nextState;
// The difficulty level (1..MAX_DIFFICULTY_LEVEL) // (Do not set to zero!) int difficultyLevel;
void setup() { // Initialise input buttons for(int i=BUTTON_YELLOW; i<=BUTTON_RED; i++) { pinMode(i, INPUT); } // Initialise LEDs for(int i=LED_YELLOW; i<=LED_RED; i++) { pinMode(i, OUTPUT); } // Set initial difficulty level to 1 random flash && put game in start state difficultyLevel = 1; currentState = STATE_START_GAME; nextState = currentState; numButtonPresses = 0; }
void loop() {
// Run the state machine controlling the game's states switch( currentState ) { case STATE_START_GAME: delay(5000); // Give player time to get ready nextState = STATE_PICK_RND_SEQUENCE; break; case STATE_PICK_RND_SEQUENCE: generateRndSequence(); nextState = STATE_SHOW_RND_SEQUENCE; break; case STATE_SHOW_RND_SEQUENCE: showRndSequence(); // Display the rnd sequence to the player nextState = STATE_READ_PLAYER_GUESS; break; case STATE_READ_PLAYER_GUESS: readPlayerGuess(); // Poll buttons and record each button press // If all inputs have been made then verify the guess if( numButtonPresses >= difficultyLevel ) { numButtonPresses = 0; nextState = STATE_VERIFY_GUESS; } break; case STATE_VERIFY_GUESS: // Check player's guess against the generated random sequence if( verifyGuess() ) { nextState = STATE_GUESS_CORRECT; } else { nextState = STATE_GUESS_INCORRECT; } break; case STATE_GUESS_CORRECT: // Player was right. Increase difficulty level and goto start game soundCorrectGuess(); difficultyLevel++; if( difficultyLevel > MAX_DIFFICULTY_LEVEL ) difficultyLevel = MAX_DIFFICULTY_LEVEL; nextState = STATE_START_GAME; break; case STATE_GUESS_INCORRECT: // Player was wrong. Sound buzzer, show correct sequence, set difficulty level to 1 and re-start game soundBuzzer(); showRndSequence(); difficultyLevel = 1; nextState = STATE_START_GAME; break; } currentState = nextState; }
// Generate a random sequence of LED pin numbers void generateRndSequence() { for(int i=0; i
// Show random sequence void showRndSequence() { for(int i=0; i
// Read a button press representing a guess from player void readPlayerGuess() { if( digitalRead(BUTTON_YELLOW) == HIGH ) { playerGuess[numButtonPresses] = LED_YELLOW; numButtonPresses++; flashLED(LED_YELLOW, true); blockUntilRelease(BUTTON_YELLOW); } else if( digitalRead(BUTTON_BLUE) == HIGH ) { playerGuess[numButtonPresses] = LED_BLUE; numButtonPresses++; flashLED(LED_BLUE, true); blockUntilRelease(BUTTON_BLUE); }else if( digitalRead(BUTTON_GREEN) == HIGH ) { playerGuess[numButtonPresses] = LED_GREEN; numButtonPresses++; flashLED(LED_GREEN, true); blockUntilRelease(BUTTON_GREEN); }else if( digitalRead(BUTTON_RED) == HIGH ) { playerGuess[numButtonPresses] = LED_RED; numButtonPresses++; flashLED(LED_RED, true); blockUntilRelease(BUTTON_RED);
void blockUntilRelease(int buttonNumber) { while( digitalRead(buttonNumber) == HIGH ) ; } // Compare the guess with the random sequence and return true if identical bool verifyGuess() { bool identical = true; for(int i=0; i
// Sound the buzzer for incorrect guess void soundBuzzer() { tone(PIEZO, 100, 2000); delay(2300); }
void soundCorrectGuess() { tone(PIEZO, 700, 100); delay(100); tone(PIEZO, 800, 100); delay(100); tone(PIEZO, 900, 100); delay(100); tone(PIEZO, 1000, 100); delay(100); tone(PIEZO, 1100, 100); delay(100); tone(PIEZO, 1200, 100); delay(100); } // Flash the LED on the given pin void flashLED(int ledPinNum, bool playSound) { digitalWrite(ledPinNum, HIGH); if( playSound ) playSoundForLED(ledPinNum); delay(1000); digitalWrite(ledPinNum, LOW); delay(500); }
void playSoundForLED(int ledPinNum) { int pitch = 0; switch(ledPinNum) { case LED_YELLOW: pitch = 200; break; case LED_BLUE: pitch = 250; break; case LED_GREEN: pitch = 300; break; case LED_RED: pitch = 350; break; } tone(PIEZO, pitch, 800); } // Get a random LED pin number int rndLEDPin() { return random(LED_YELLOW, LED_RED + 1); }
2 Comments
Penolopy Bulnick 4 years ago
FreebiePlayz 4 years ago
