Introduction: Arduino Uno Ultrasonic Distance Measurement Tutorial: From Setup to Code
Unlock the power of precise distance measurement as we explore the seamless integration of an Arduino Uno with an ultrasonic sensor. I guide you through the steps to set up this dynamic duo, opening doors to a world of innovative projects and applications. Let's dive in!
List of materials used:
1) Arduino UNO R3 - 1
2) HC-SR04 [Ultrasonic Sensor] - 1
3) UART cable - 1
Step 1: Introduction
Ultrasonic Sensor [HC-SR04]
  1. Principle: The ultrasonic sensor works on the principle of SONAR and RADAR system which is used to determine the distance to an object.
  2. Formulae used: distance = (speed*time)/2
Total distance = ( 343∗time of echo pulse)/2
3.Range: 2cm to 400 cm
Step 2: Connections
Sensor connections:
1) Connect the 5V pin of Arduino Uno to the Vcc of the Ultrasonic Sensor.
2) Connect the gnd pin of Arduino Uno to the gnd of the Ultrasonic Sensor.
3) Connect pin 6 of Arduino Uno to the trig pin of the Ultrasonic Sensor.
4) Connect pin 5 of Arduino Uno to the echo pin of the Ultrasonic Sensor.
Step 3: Code
// Pins
const int trig= 6;
const int echo= 5;
// Variables
int distance;
long duration;
void setup()
pinMode(trig, OUTPUT); // sets the trig as output
pinMode(echo, INPUT); //  sets the echo as input
Serial.begin(9600);   // sets the serial communication
void loop()
digitalWrite(trig, LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH); // Sets the trigPin on HIGH state for 10 micro seconds
delayMicroseconds(10);
duration = pulseIn(echo, HIGH);
distance = duration * 0.034 / 2;   // Reads the echoPin, returns the travel time in microseconds
Serial.print("Distance in cm: ");  // prints the distance in centimeters on the serial monitor
Serial.println(distance);
Step 4: Conclusion
To accomplish the desired result, follow the steps above. The fundamental illustration of using an Arduino Uno and an ultrasonic sensor is presented above.
For any questions, contact: gy802655@gmail.com.
