Introduction: Arduino: Use LED As a Light Sensor
A while ago, I read a blog post about using a normal LED as a light sensor. After browsing around the Internet, I found that all the examples that I found were not working well or hard to read. Then I stumbled upon this instructable: https://www.instructables.com/id/LED-as-lightsensor-on-the-arduino/
However, I found that the code was kind of hard to read/edit and it missed a serial output. Below is the cleaned up code with serial output. In addition, I found that adding a 100R resistor in series with the sensing LED greatly improves the sensitivity. This change improves the range of light on the serial port from 290-270 to 290-120.
#define READ A0
#define LED 13
int basis = 0;
void setup() {
pinMode(LED, OUTPUT);
Serial.begin(57600);
void loop() {
int sens = readLED(50);
basis = sens - 20; // setting sensitivity - now it will react if the LED is 20 lower than the setting above
for(int y = 0; y < 1000; y++) { // after every 1000 tests the program will reset the led to cope with changing light
sens = readLED(50);
Serial.println(sens);
if (sens < basis) // testing is the led was in the dark
digitalWrite(LED, HIGH);
else
digitalWrite(LED, LOW);
int readLED(int number) { // Read analog value n times and avarage over those n times
int totaal = 0;
for(int x = 0; x < number; x++) {
totaal += analogRead(READ);
delay(10);
return totaal/number;
#define READ A0
#define LED 13
int basis = 0;
void setup() {
void loop() {
sens = readLED(50);
else
int totaal = 0;
delay(10);
