Introduction: Arduino Web Server With Sensors
I made it for learn how to use the sensors.
And i want to turns on/off my ventillator if im not at home.
So if im not at home than i can watch my room status.
Later i want to make E-mail notification.
If you access your Arduino's ip in router forwarding (port:80) then you can connect to your Website everywhere are u.
If you want to made it you need:
- Arduino Microcontroller
- Ethernet Shield
- DHT11 sensor
- 4x4 matrix keypad
- Raindrop sensor
- Relay
- Gas sensor
- IR Flame sensor
The web server example: http://startingelectronics.com/tutorials/arduino/e...
Step 1: Relay. How to Work?
How to connect my lamp to Relay?
You can see the picture, its easy.
Relay connect to Arduino?
Relay -> Arduino
VCC -> 5V
GND -> GND
IN1 -> Choose a Digital Input
Arduino Program code:
#define RELAY1 6 // Relay in Digital input 6
void setup()
pinMode(RELAY1, OUTPUT);
void loop()
digitalWrite(RELAY1,LOW); // Relay turns on
delay(2000); // Wait 2 seconds
digitalWrite(RELAY1,HIGH); // Relay turns off
Step 2: 4x4 Matrix Keypad. How to Work?
How to connect 4x4 Matrix KeyPad to Arduino?
First 4 pin: ( Connect to Digital inputs )
Its return back with the column number when you press a button.
The last 4 pin: ( Connect to Digital inputs )
Returns back with the row number.
byte colPin[4]={22,24,26,28}; // Column Pins
byte rowPin[4]={23,25,27,29}; // Rows PinsExample:
You have a 4x4 matrix keypad.
char keys[4][4]=
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}};
If you press the 2nd column and 2nd row button.
The program is write out the '5' in the serial port.
For Example:
#include
char keys[4][4]={ {'1','2','3','A'},
{'4','5','6','B'}, {'7','8','9','C'}, {'*','0','#','D'}}; byte colPin[4]={22,24,26,28}; byte rowPin[4]={23,25,27,29}; Keypad keypad=Keypad(makeKeymap(keys),rowPin,colPin,4,4); void setup() {
Serial.begin(9600);
pinMode(8, OUTPUT);
void loop() {
char pressed=keypad.getKey();
if(pressed) {
Serial.println(pressed); }
Step 3: DHT11 Sensor. How to Use?
How to read templature and humidity?
For Example:
#include
dht11 DHT11; #define DHT11PIN 3
void setup() { Serial.begin(9600); }
void loop() { DHT11.read(DHT11PIN); // This method is reading new humidity and temperature. Serial.print(DHT11.humidity, 1); Serial.println(DHT11.temperature, 1); delay(1000); }
Step 4: Raindrop Sensor. How to Work?
How to connect the sensor with your Arduino?
OV -> Analog input
GND -> GND
VCC -> 5V
The Sensor Value:
The sensor is returns back with a value.
More than 1000: Its Dry
If less than 1000: its Wet
For Example:
void setup()
Serial.begin(9600);
void loop() {
int sensorValue = analogRead(A0); // Its read a value.
Serial.println(sensorValue);
delay(100);
}Step 5: IR Flame Sensor. How to Work?
OV -> Analog input
GND -> GND
VCC -> 5V
The Sensor Value:
About 900: Normal
If less: Detected Fire
For Example:
void setup()
void loop() {
Serial.println(sensorValue); delay(100);
Step 6: MQ-2 Gas Sensor. How to Work?
OV -> Analog input
GND -> GND
VCC -> 5V
The Sensor Value:
About 100: Normal
If more: Detected Gas
For Example:
void setup()
Serial.begin(9600);
void loop() {
delay(100);
