Introduction: Arduino Wi-Fi AC Energy Meter
Introducing an accurate AC energy meter that is Wi-Fi enabled. The meter has a power range of 5W to 3.2kW and measures True RMS volts, True RMS current, Real power, Power factor, kilowatt-hours and includes a scrolling plot of AC voltage variation over time. All data is sent once every second via Wi-Fi to a free Android App called "RoboRemo". For this project we will utilize an Arduino Nano, an 8266-01 Wi-Fi module and an ACS712 current sensing module. This instructable will explore the theory behind AC power measurements , explain how the circuit works and show how to download and customize the RoboRemo application.
All the pertinent files will be accessible via my GoogleDrive
https://drive.google.com/drive/folders/1NvK4f2d-y5f26P7TWCwK2i0CpFPwBIqd?usp=share_link
Arduino Nano - Note: an Arduino UNO or MEGA can be substituted
ESP8266-01 module
ACS712-20 - Current sense module
5V Power Supply (500mA min) - I used a small 5V USB Charger
LMC7111 - Op-Amp rail to rail Note: LM321,LM324 or M358 can be substituted limiting the dynamic range of ACS712
LM78M33 - 3.3V regulator SOT-223 package Note: Any suitable 3.3V regulator can be substituted
220k resistor 1Watt
10K resistor (x5)
2.7k resistor (x2)
1k resistor (x3)
1uF electrolytic capacitor (x2) 10 volts or greater
100nF ceramic capacitor (x3)
Pin Header strip - Female
Terminal block 5mm 2 pin (x4)
AC lamp cord wire
small guage hook-up wire
Step 1: Board Assembly
I etched my own PCB but initially I built and tested it on a solderless breadboard
Step 2: Introduction and Project Topics
Please watch this short video to see what we will be discussing as part of this instructable
Step 3: AC Measurement Theory
Please watch this short video for a detailed explanation of how we go about measuring AC voltage and power.
Below are some additional resources to checkout;
RMS Voltage Tutorial - https://www.electronics-tutorials.ws/accircuits/rms-voltage.html
Power Triangle and Power Factor Tutorial - https://www.electronics-tutorials.ws/accircuits/power-triangle.html
Voltage and current Measurement of Non-Sinusoidal AC Power https://www.pge.com/includes/docs/pdfs/mybusiness/customerservice/energystatus/powerquality/nonsinusoidal_power.pdf
Step 4: Simplified Block Diagram
Please watch this short video for a detailed explanation of how the AC Meter is implemented.
Step 5: Schematic
Please watch this short video to understand the schematic
Step 6: Arduino Nano Code
Please watch this short video to understand how the code was written.
Dont forget to visit my google drive in order to get the "send_robo_remo" library folder
Simply place the folder in your Documents\Arduino\libraries folder
Step 7: RoboRemo Install and Setup
Please watch this video to be able to download and set up the graphical user interface called RoboRemo
Step 8: Wi-Fi Setup
Please watch this video to learn how to program and setup the Wi-Fi connection in order to connect the ESP8266 to your Wi-Fi network
You will need to be able to program the 8266-01 module. You can use your Arduino board to accomplish this. To find out how watch my tutorial. https://youtu.be/S-nAHeIHXCk
Step 9: Final Setup and Demo
Finally, we complete the RoboRemo Wi-Fi connection and can send real time AC measuement data to the RoboRemo Application.
