Introduction: Arduino Leonardo Usb Steering Wheel
I had an old usb steering wheel laying around that died, i had a freetronics leostick laying around so i made this.
i updated the bootloader to the official leonardo one.
Step 1: Bootloader Mods
for the steering wheel you will need an arduino leonardo compatible board with the leonardo bootloader.
update these files in root folder >hardware > arduino > cores > arduino
i used i.0.5 of the ide
files to download : HID
Step 2: Code and Wiring
here is the code i used, edit it to suit your needs :)
void setup()
Serial.begin(57600);
pinMode(13, OUTPUT);
joySt.xAxis = 0;
joySt.yAxis = 0;
joySt.zAxis = 0;
joySt.xRotAxis = 0;
joySt.yRotAxis = 0;
joySt.zRotAxis = 0;
joySt.throttle = 0;
joySt.rudder = 0;
joySt.hatSw1 = 0;
joySt.hatSw2 = 0;
joySt.buttons = 0;
void loop()
Serial.write("DIY USB joystick V1 by the nerdling");
joySt.xAxis = analogRead(A4)/4;
joySt.yAxis = analogRead(A5)/4;
joySt.rudder = analogRead(A3)/4;
Joystick.setState(&joySt);
the wiring is what i used on my wheel, the throttle and brake wiring is what i used because i needed 2 pedals for 1 channel, try it out and see what you need to do to make it suit you
that's all i will tell you because that's all you need figure the rest out e.g to put it all in your wheel each one is your different
void setup()
joySt.xAxis = 0;
joySt.yAxis = 0;
joySt.zAxis = 0;
joySt.xRotAxis = 0;
joySt.yRotAxis = 0;
joySt.zRotAxis = 0;
joySt.throttle = 0;
joySt.rudder = 0;
joySt.hatSw1 = 0;
joySt.hatSw2 = 0;
joySt.buttons = 0;
void loop()
