Introduction: Arduino Nano Controling a Dental Vacuum Motor by Checking Liquid Waste Level
////////////// DESCRIPTION ///////////////////////////////////////////////////////////
This is an application for controling a dental vacuum motor.
The motor needs a 24 volt signal(via a relay connected to arduino's digital output) to turn ON.
When its turned ON it fills a bootle with liquids form patient's mouth.
Bottle has two level switches (sensors) for LOW and HIGH level of liquid.
Motor state must be ON until liquid reaches high level.Then motor state must be OFF so liquid goes to drain (that happens only when motor is OFF) and then turned ON again.
All this works when dental vacuum tips are on doctors hands.
The stand for dental vacuum tips has a switch so when placed in stand the switch is OPEN and when in dentist's hand the switch is CLOSE.
*****************code by ALEXANDROS PAGONIDIS http://www.BiomedicalTechnology.gr *********************************************************
#include <Time.h> //arduino can read time for 50 days from initialization and then resets time again
unsigned long time;
unsigned long time2;
/////*** numbers of pins************************/////
int lowLevelPin = 2; // digital pin ( 2) connected to LOW level switch of bootle. Pin 1 of switch goes to digital pin of arduino and pin 2 of switch goes to GROUND.
int highLevelPin = 3; // digital pin ( 3) connected to HIGH level switch of bootle. Pin 1 of switch goes to digital pin of arduino and pin 2 of switch goes to GROUND.
int valveTipsPin = 4; // digital pin ( 4) connected to the stand's switch where vacuum tips are placed. Pin 1 of switch goes to digital pin of arduino and pin 2 of switch goes to GROUND.
int motorPin =12; // digital pin 5V DC relay module witch controls motor's 24V AC singal (CAUSE MY CHINESE MODULE IS STUPID LOGIG IS INVERTED SO WHEN POWER OFF NO TO TURN ON THE MOTOR)
int ledPin =13; // internal led of arduino board
THIS CONNECTIONS ARE FOR SPECIFIC SIRONA CHAIR WITH CATANNI ELECTRONICS
PINS AND SOME OF CABLES COLORS:
1,19,12,13,14 : NOT CONNECTED
2, 3: 24VAC INPUT FROM BOX
9,11: 24VAC OUTPUR TO MOTOR (PINS 3,9 ARE PINS OF A NORMALLY OPEN RELAY)
4, 5: TIPS SWITCH (WHERE IN PIN 4 YELLOW-BROWN CABLES 5 WHITE-GRAY CABLES
6 : BOTTLE HIGH LEVEL SENSOR (CABLE RED )
7 : BOTTLE LOW LEVEL SENSOR (CABLE WHITE)
8 : BOTTLE COMMON,MIDDLE (CABLE BLACK)
/////*** values of swithes state (HIGH=OPEN or LOW=CLOSE)
int valveTipsVal;
int lowLevelVal ;
int highLevelVal;
/////*** delay times in msecs*******************/////
int timeOfReadings = 200;
int problemInLowLevelSwitch = 8000;
int timeOfMotorMinON = 4000;
int timeOfMotorMaxON = 8000;
int timeOfTipOnStand = 2500;
int timeOfTipRest = 999;
/////*** val that states if motor is ON Or OFF***///
int motorState; // gets values of 0 or 1
void setup()
//configure pins as an input and enable the internal pull-up resistor
pinMode(lowLevelPin,INPUT_PULLUP);
pinMode(highLevelPin,INPUT_PULLUP);
pinMode(valveTipsPin,INPUT_PULLUP);
//configure pins as outputs
pinMode(motorPin, OUTPUT);
pinMode(ledPin, OUTPUT); //internal on chip led indicator
motorOFF(); // When arudino TIPS_CHECKs up motor should be turned OFF
}// end of setup
void loop()
digitalRead with INPUT_PULLUP setup reads:
HIGH when a switch or button is as an open connection to the ground.
LOW when a switch or button is as a closed connection to the ground.
valveTipsVal=digitalRead(valveTipsPin);delay(1); //read
lowLevelVal =digitalRead( lowLevelPin);delay(1); // all
highLevelVal=digitalRead(highLevelPin);delay(1); // swithes
TIPS_CHECK:
while (valveTipsVal == LOW) //TIPS_CHECK while ***** when vacuum tips are in dentist's hand, stand's switch is closed. *****
if (valveTipsVal==HIGH)
{goto TIPS_CHECK;} // check on all levels of code if valve tips are on stand and if yes goto TIPS_CHECK
delay (timeOfReadings); //time of readings...wait for sensors to stabilize and calm down proccessor from many readings
LEVEL_CHECK_RUN:
lowLevelVal =digitalRead( lowLevelPin);delay(1); //read
highLevelVal=digitalRead(highLevelPin);delay(1); // level swithes
if (lowLevelVal == HIGH && highLevelVal == HIGH) // if high level switch OPEN, low level switch OPEN
{lowLevelVal =digitalRead( lowLevelPin);delay(1);
motorON();
if (highLevelVal == HIGH && lowLevelVal == LOW) // if high level switch OPEN, low level switch CLOSE
motorON();
while (highLevelVal == LOW) // LEVEL_CHECK_RUN while //while high level switch is CLOSE
motorOFF();
if (highLevelVal == HIGH) //if !!!03!!! need an if before the while so get time and runonce outside of the while loop
int runonce=0; // to run once some procedures inside the next while !!!03!!!
time = millis();
while (highLevelVal == HIGH) //while !!!03!!!
{ lowLevelVal =digitalRead( lowLevelPin);delay(1); //read
time2 =millis();
if ( time2 > (time +problemInLowLevelSwitch) && lowLevelVal !=HIGH && (runonce == 0) ) //if low level switch has a problem and doesn't go off
{ runonce ++; //with a runonce parameter to stop counting
delay(timeOfMotorMinON); //motor stay turned of for a delay and then turned on again
motorON();
//goto LEVEL_CHECK_RUN; //need to use this in case you don't use the runonce statement
if (lowLevelVal == HIGH && (runonce == 0)) //if low level switch is closed
{ runonce ++;
delay(timeOfMotorMaxON); // motory stay turned of foa delay and then turned on again
// so liquids go to drain.
motorON();
//goto LEVEL_CHECK_RUN; //do not use but if you use it works all right.
} //end of while !!!03!!!
} //end of if !!!03!!!
} //end LEVEL_CHECK_RUN while
} //end of LEVEL_CHECK_RUN
} // end of TIPS_CHECK while ******under this line code belongs to case that tips are on stand*******
//motorOFF();
switch(motorState) // when vacuum tips are in stand, stand's switch is open so motor must be off.
// but if motor was turned ON then when dentist's puts the tip on stand
// there must be a delay so waste-liquid inside vacuum tubing goes to boottle and than drain.
case 1: delay(timeOfTipOnStand);
motorOFF();
break;
case 0: delay(1);
motorOFF();
break;
default: break;
delay(timeOfTipRest); // precausion in case tip doesn't fit or tip come out at once.
} //End of loop//////////////////////////////////////////
void motorON() //turn motor ON and motorstate 1
{ //this is for the switch(motorstate)
digitalWrite(motorPin, LOW); // YES LOW(inverted logic), cause of stupid chinese module
delay(1);
motorState = 1;
digitalWrite(ledPin, HIGH);
delay (1);
void motorOFF() //turn motor off and motorstate 0
digitalWrite(motorPin, HIGH); // YES HIGH(inverted logic), cause of stupid chinese module
delay(1);
motorState = 0 ;
digitalWrite(ledPin,LOW);
delay (1);
void blink() //put in code for testing where you are when using swithes
digitalWrite(ledPin, HIGH); // sets the LED on
delay(200); // waits for a second
digitalWrite(ledPin, LOW); // sets the LED off
unsigned long time;
int valveTipsVal;
int lowLevelVal ;
int highLevelVal;
void setup()
}// end of setup
void loop()
TIPS_CHECK:
LEVEL_CHECK_RUN:
motorON();
motorON();
motorOFF();
time = millis();
time2 =millis();
motorON();
{ runonce ++;
motorON();
//motorOFF();
motorOFF();
break;
case 0: delay(1);
motorOFF();
break;
default: break;
delay(1);
motorState = 1;
delay (1);
delay(1);
motorState = 0 ;
delay (1);
