Introduction: Arduino+DS18B20 Temperature Sensor (buzzer Alarm)
ds18b20
Features: Adaptable to a wide voltage range, 3.0~5.5v, single-wire data transmission, multiple temperature sensors can be connected on three wires, and temperature can be measured at multiple points. When the positive and negative poles are reversed in a short period of time, the chip will not be burned, but it will not work properly.
Measuring temperature range: -55℃~+125℃
Programmable resolution, 9 to 12 bits, respectively 0.5℃, 0.25℃, 0.125℃, 0.0625℃. Default 12-bit precision
- arduino mega2560 (same as uno and other series)
- ds18b20 temperature sensor (waterproof package)
- lcd1602A (save io port, external pcf8574, four-wire driver)
- Some Dupont lines
Step 1: Circuit
ds18b20, an external terminal adapter is connected here. If there is no terminal adapter, just connect an external pull-up resistor of about 1k ohms at the data end (the chip resistor on the module only uses 472 ohms)
Step 2: Dallas Temperature
Call the library and simply implement the function program as follows:
Step 3: Coding
#include <OneWire.h>
#include <LiquidCrystal_I2C.h> //4-pin pcf8574 driver lcd1602 library
#include <DallasTemperature.h> //ds18b20 library
#define buzzpin 6 //Define buzzer pin 6
#define Onewire_bus 7 //ds18b20 connects to pin 7
OneWire oneWire(Onewire_bus);
DallasTemperature sensors(&oneWire);
LiquidCrystal_I2C lcd(0x27,16,2); //The I2C address of LCD1602 is 0x27. LCD1602 is a two-line, 16-character LCD display.
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
lcd.init(); // Execute LCD I2C communication initialization twice
delay(20);
lcd.init();
delay(20);
lcd.backlight();//Light up the LCD backlight
void loop() {
// put your main code here, to run repeatedly:
delay(50);
Serial.print("Get temperature:"); // Send a few words
sensors.requestTemperatures(); //Get the temperature
Serial.println(sensors.getTempCByIndex(0));
lcd.setCursor(0, 0); // Move the LCD cursor to the first position 0, 0 (column, row)
lcd.print("temp:");
lcd.print(sensors.getTempCByIndex(0)); // Sensor temperature value
lcd.print(" C"); // Continue writing the previous statement
if(sensors.getTempCByIndex(0)>40) //Alarm when temperature is greater than 40
digitalWrite(buzzpin,HIGH);
else
digitalWrite(buzzpin,LOW);
delay(10);
Step 4: Testing
There is no water put here, just touch the temperature test
Step 5: Problem1
If the lcd1602IIC address is not 0x27, you can find it through the following program. The serial port sending address
#include <Wire.h>
void setup() {
Serial.begin (115200);
while (!Serial) { }
Serial.println ();
Serial.println ("I2C scanner.Scanning ...");
byte count = 0;
Wire.begin();
for (byte i = 8; i < 120; i++) {
Wire.beginTransmission (i);
if (Wire.endTransmission () == 0) {
Serial.print ("Found address: ");
Serial.print (i, DEC); Serial.print (" (0x");
Serial.print (i, HEX); Serial.println (")");
count++; delay (1); // maybe unneeded?
} // end of good response
} // end of for loop
Serial.println ("Done.");
Serial.print ("Found ");
Serial.print (count, DEC);
Serial.println (" device(s).");
} // end of setup
void loop() {}
Step 6: Problem2
IIC address error
There is a potentiometer behind the welded pcf8574 adapter board. If the serial port displays the value normally but the LCD does not display the value, you can adjust the potentiometer and the LCD brightness will be displayed after adjustment.
