Introduction: Arduion Based Smart Timer Switch
In this instructable, I will show how I made this Smart Timer Switch.
I got the idea of a Smart timer switch when I face a problem with cellphone charging during bedtime. many cases I forget to turn OFF the switch and this same happened during laptop charging.
This timer switch solves all those problems.
Set the timer with a smartphone and when time gets over power in the switch turned OFF.
Step 1: Creating Relay Module for Timer Switch
Collect the components and solder them according to Circuit.
Make sure that arrange components in such a manner that it can fit AC Power Socket.
You can use BC547 Transistor if you are unable to find a 2N2222 transistor.
Step 2: Connecting Arduino Nano With Relay Module , Bluetooth Module and Power Supply
Arduino nano Pin .................................................Relay Module
GND Pin------------------------------------------------------GND Pin
5V Pin---------------------------------------------------------Vcc Pin
Pin 5-----------------------------------------------------------Trigger Pin
Arduino Nano Pin..............................................HC05 Bluetooth Module
5V PIn-------------------------------------------------------5V Pin
GND---------------------------------------------------------GND
TX------------------------------------------------------------RX
RX------------------------------------------------------------TX
Arduino Nano Pin..................................................Power Supply
Vin---------------------------------------------------------------5V Output
GND-------------------------------------------------------------GND
All Connections are included in the previous step Circuit.pdf File
Step 3: Now Combining Everything
In this Step, I am going to combine everything inside AC Power Plug.
make sure you have insulated everting with a paper tape or any insulating material and upload the code in Arduino board.
Now Hardware Part is completed.
Step 4: Creating Android App in MIT App Inventor and Programming Arduino Nano
In this Step, I am going to create an android app using MIT app inventor and Programming Arduino board.
The App I have made in-app inventor beeps a sound when time is triggered and send latter x to the HC05 Bluetooth Module.
I have included All Files in Zip folder you can download it from here.
