Introduction: Are There Easier Ways to Make a Paracord Necklace or Bracelet?
An answer to this question... Um, duh!
This intractable will show you an easier way to make a paracord necklace/bracelet that uses less paracord and will only take you five minutes to make.
In a survival situation, you can use the extra paracord you saved on this project as food, or use it to fend off bear attacks! (just a suggestion) .
So lets get started.
Materials:
paracord- (about an arms length will do) (for those of you who are "winging it challenged" and need to have a specified measurement, about 30 inches should be fine)
hands- (you can use your own, or use someone else's (a reference to all you Tom Sawyer's out there))
Step 1: Tie It Together
All you need to know are how to tie a fisherman's knot.
It's so easy, even a fisherman can do it.
First: make an oval with the paracord, both ends of the cord should overlap as shown.
Then: tie a fisherman's knot on both sides.
If you don't know how to tie a fisherman's knot, here's an explanation:
Make an "x" using one end of the paracord as shown.
Pull the working end, 'the end you're moving', through the hole you made from the "x".
If you're still not sure, and my pictures don't help, here's a wikipedia link that will help explain it better (their pictures help): http://en.wikipedia.org/wiki/File:Spierenstich-1.j...
This necklace is like the double uni knot without the 3 other wraps on each end:
http://www.netknots.com/fishing_knots/double-uni-k...
If the internet isn't helpful, here's a secret... It doesn't have to be a fisherman's knot! You can make up your own knot so long as you get it to slide. The fisherman's knot just happens to be a simple slip knot that
Step 2: Enjoy
To adjust your new necklace, simply pull on both ends of the knot to adjust the size. If you want it to be snug on your neck, all you need to do is slide the knots inward. If you want it to be lose, all you have to do slide the knots outward.
If you want to wear the paracord on your wrist, slide the knots inward and wrap the paracord around your wrist as many times as you need.
You're done!!!
Enjoy :)
Step 3:
Step 4:
Makerlympics Contest
Paracord Contest
4 Comments
8 years ago on Step 2
Simple - I like that. You can add a bead to it. Also, if you are involved in a non-profit group you can make in the 'colors' of the group and sell. Since this only costs pennies to make (sans charm) you can easily sell for 2-4.00, great for some fundraising. Thanks for the instructions - have seen several different instructions and yours are the best. Plus, this can go from necklace to bracelet making it more versatile . :)
8 years ago
Nice! However, as a tip for future Instructables, do not use a question for a title. Also refrain from using "duh." Overall, this is a great project! :)
8 years ago on Introduction
Steps 3 and 4 confuse me...
Sorry about that kiteman. I tried to get rid of them but couldn't figure out how. I could have filled them up with fluff but I try to make my instructables as simple as possible. :)
