Introduction: Art From a Knitting Sampler
I enjoy creating art using a variety of mediums, mostly natural ones. This wall hanging utilizes cotton, wool, steel, and wood.
The knitting portion took about 3 hours, and the display portion about another hour.
I have two other canvases on my wall in this particular room which I tried to bring the outdoors in. This third piece is a slightly different interpretation of those, and ties in nicely.
Step 1: Basketweave and Snake
For the 6" x 6" basketweave sampler,I used pink cotton yarn and US 6 needles.
Cotton yarn has little flexibility, compared to wool or acrylic, but also gives a crisper look to the stitches.
I made this knitting tube for an instructables contest for zip ties. It works so great! I have knitted probably 100' using it; still going strong!
The green tube was made using two strands of green yarn in slightly different tones.
Step 2: Board and Nails
The wood is leftover hickory from our house build, and the nails are antique style flooring nails.
Gave it a good sanding, slightly rounded the edges, then gave it a coat of tung oil.
I wanted the holes in a slightly random pattern, to give more interest when I strung them with jute. Pre-drilling was necessary and made the hammering easy. I used a backer board and drilled all the way through. The nails ended up being hammered in just halfway.
Step 3: Floating the Sampler Onto Board
Using a yarn needle and jute, I centered the sampler onto the board and sewed through various points to attach to the nails.
Tightened any slack up slightly, then knotted and snipped.
Step 4: Sewing Tubes Into "vase" and Displaying
I tucked the two tubes in, and decided on a slightly off-balanced position, then sewed them to sampler using pink thread and needle.
Using two of the backs of the holes from the pre-drilling, I installed two wide-head screws, then wrapped wire around both of them.
I hammered a picture hanging hook onto the wall, and voila!
A great way to use up small amounts leftover from various projects.
For lots more original DIY content, visit me on Locals!
