Introduction: Art Wreath
About: i like swimming and reading.Im am good with kids and love taking care of them
I made this artsy project because I thought it would be cool and kind of pretty on my door and others who might make it too.You will defintely love this project because it's fun and always turns out good in you own way.
you need a Climbing euonymus,a Sawara False Cypress and zinias for the outdoor part.For the decorating part you need paint, glitter, a carbord box,a paint brush,and tape.
Step 1: Cutting the Carboard and Taping It
First,you cut a square out of carboard, but slightly big.When you cut the square out of the carboard you need clear tape to tape it all together.
Step 2: Collect All the Plants and Flowers
You need four zinias and 4 zinia leaves , you also need to cut some of the stuff off of the Climbing euonymus and the Sawara False Cypress.
Step 3: Paint the Flowers and Leaves
Now you put somewhat alot of paint in the 2 bowls [you can use any color you want] and dip the zinias in the bowls.Then you put the leaves in the bowls and smudge them around one at a time.Once your done painting the leaves you put glitter on them and put everything you painted on a towel to dry for 2 hours.
Step 4: Put It on the Square Carboard
After everything dries, you put the zinias at each corner on the square.Then you put the painted leaves under the zinias but leave them hanging out a little.Then you take the Climbing euonymus you cut and take 12 tiny leaves.Next you put 3 leaves under the zinias but also hanging out toppled on each other.
Step 5: Painting the Carboard and Using Glue
You use the paint brush and paint whats not covered on the carboard for prettiness.When the paint dries you then paint the glue over the carboard [a lot prefabaly].Then you take the stuff you cut from the Climbing euonymus and stick it on the gtued parts and let it dry.
Step 6: Taping
Next you tape the zinias down with clear tape.
Step 7: Put the Final Touch
You take the top peice from the Climbing euonymus and glue the bottom of them[you need four].Then you put one in the midle of each side.Let it dry and your done.
