Introduction: Assemble OSOYOO Model-3 Robot Car for Arduino
The OSOYOO Model 3 Robot Car DIY Starter Kit for Arduino is an exceptional entry point into the world of robotics and programming. This comprehensive kit is designed to provide beginners and enthusiasts with all the necessary tools and resources to build and program their very own robot car.
In this project, we will install the fundamental framework of the robot car and program it to perform basic movements in the subsequent steps.
With step-by-step instructions and meticulously curated components, the kit empowers users to assemble a functional robot car that can be controlled and customized using the Arduino platform. The kit includes a range of modules such as motors, sensors, wheels, and an Arduino board, enabling users to delve into exciting projects like line following, obstacle avoidance, and remote control.
For this Arduino robot car kit, you need the components shown in the picture.
You can get the component package from the link below:
Step 1: Remove the Protective Film
Remove the protective film from the Chassis
Step 2: Install the Motor
Install the motor under the chassis with M3 Hex screws and nuts
Step 3: Install the Universal Wheel
Install the universal wheel with the M3 Hex screws and copper pillars
Step 4: Install the Universal Wheel
Install the universal wheel under the chassis with the M3 Hex screws
Step 5: Install OSOYOO UNO Board
Install OSOYOO UNO Board on the chassis with M3 plastic screws, pillars, and nuts
Step 6: Install the Battery Box
Install the battery box on the chassis with M3 Phillips screws and nuts
Step 7: Plug the OSOYOO Motor Shield Board
Plug the OSOYOO Motor Shield Board in OSOYOO UNO board
Step 8: Install the Voltage Meter
Install the voltage meter on the chassis with M3 plastic screws, pillars, and nuts
Step 9: Connect OSOYOO Motor Shield With the Motor
More detail about OSOYOO Motor Shield, please refer to this link:
https://osoyoo.com/2023/01/16/introduction-of-osoyoo-motor-shield-v1-1-v1-2/
Step 10: Connect OSOYOO Motor Shield With the Battery Box
Step 11: Connect OSOYOO Motor Shield With the Voltage Meter
Step 12: Install the Wheels
Hardware installation is nearly complete. Prior to inserting the battery into the box, it's essential to first upload the sample code to the OSOYOO Basic Board for Arduino.
Step 13: Software Installation
Acquire the code from https://osoyoo.com/picture/2WD_Car_V2.0/code/lesson-1.zip, extract the files, and proceed to upload them to the IDE.
Step 14: Testing
Detach the OSOYOO Basic Board for Arduino from your PC. Confirm the power switch on the OSOYOO Motor Shield is off. Insert a 9V battery into the designated compartment, ensuring correct polarity to avert potential device damage and fire hazards.
Position the car on the ground. Activate the OSOYOO Motor Shield switch. The car should exhibit the sequence: forward, backward, left turn, right turn, then come to a halt.
If the car's behavior contradicts the expected outcome mentioned above, meticulously examine your wire connections, validate the status of the 7 jumper caps on the OSOYOO Motor Shield, and ensure the battery voltage exceeds 7.2V.
