Introduction: Atrari Punk Console Using Two 555 Timers
Atrari Punk Console
Atari Punk Console can be constructed by using two 555 timer or a single 556 dual timer IC to create a low-fi low. In this instructable, I will create a simple DIY low cost noisemaker circuit with the instruction from BrownDogGadgets. https://www.instructables.com/id/Build-an-Atari-P...
Required Parts
Breadboard Jumper wires (12 to 15) 9V Battery 9V Battery Clip Two Ne555 or one single 556 Time 8 Ohm speaker Resistor: 1k ohm Two 500K Ohm Variable Resistor (Potentiometer) One 5K Ohm Variable Resistor (Potentiometer) Capacitors: Two 10n
What is 555 timer? 555 timer is an integrated circuit. It is commonly used in a timer and oscillator generators. The basic 555 timer has three 5 kΩ resistors connected internally.
Step 1: Schematic
Schematic
Step 2: We Can Also Use One 556 Timer Instead of Two 555 Timers.
Step 3:
First of all, we will assemble two 555 timers on the top of the board.
Put two 500k pots on one side and other 1k pot on the right bottom side.
Step 4:
Connect positive rail to the one of 500k ohm resistors using a jumper wire. (The orange jumper wire indicated by blue arrow in the photo below )
Put the green jumper wire to the pin 10 (discharge A)
Step 5:
Use the resistor to connect pin 2 and pin 7 of the upper 555 timer.
Connect pin 2 of the upper 555 timer with negative trail and pin 2.
Step 6:
Step 7:
Connect Pin 1 of the upper 555 timer to negative rail
Connect Pin 1 of the lower 555 timer to negative rail
Step 8:
Connect Pin 8 of the upper 555 timer to positive rail
Connect Pin 8 of the lower 555 timer to positive rail
Step 9:
Connect the middle leg of the variable resistor to the positive rail using a jumper.
Step 10:
Take a jumper and connect Pin 7 to Pin 6 of the second timer.
Step 11:
Connect Pin 6 of second timer with negative rail using capacitor.
Step 12:
Connect Pin 6 of the second resistor to the outside leg of the 5K Ohm Variable resistor.
Step 13:
Take your speaker and connect one wire to the middle leg of the variable resistor.
Connect one wire of the speaker with the middle leg of the resistor. Connect the other wire with pin 3 of the second timer
Step 14:
Connect pin 2 and 3 of the second timer (In the image below, it’s yellow wire indicated by the purple arrow.)
Step 15:
Apply 9V battery
