Introduction: Attendance System by Face Recognition
introduction:
In the context of technology, we live in a great scientific time that requires us to use technological tools and means from a scientific point of view to achieve the greatest possible benefit. The feature of facial recognition is considered one of the modern sciences that we will benefit from mainly in our modest project.
Project Idea:
Using a facial recognition camera, powered by Raspberry Pi4, and linking it to a database to prove attendance and absence using Python programming.
Attendance system:
Attendance system based on the algorithms of the front face by analyzing the saved and captured images by the camera and comparing them and showing the result and saving it in a database to prove attendance and departure
Raspberry Pi 4
Two HD Microsoft cameras
Touch screen display for Raspberry 7inch
Two speakers
Two Push buttons
One Speakers power supply(1A)
One Raspberry power supply (3A)
Computer mouse
One Box
Two Camera installation base
Step 1: Step 1: Gathering Supplies
1-Raspberry Pi 4
https://www.amazon.com/dp/B07TC2BK1X/ref=twister_B...
2-Two HD Microsoft cameras
https://www.amazon.com/Microsoft-T3H-00013-LifeCam...
3-Touch screen display for Raspberry 7inch
https://ar.banggood.com/Raspberry-Pi-4B-LCD-Capaci...
4-Two speakers
we bought it from local store
5-Two Push buttons
6-One Speakers power supply(1A)
7-One Raspberry power supply (3A)
8-Computer mouse
9-Box
we went to a local store to make it
10-Two Camera installation
Step 2: Step 2 Gather Information on Programming and Library Used in the Project
first:
we upgrade the system to python 3.7
second:
We used the opencv2 library in programming and the code was downloaded successfully without any problem
The process of downloading OpenCV2 took about two days. At the beginning, we downloaded the library then we update it . it took us from the morning to the night to get updated
After that, we downloaded the second command, then we added the download command from the source, in the seventh command it took time until the next day we found it had been downloaded and then we added eight steps that took about an hour and the download finished.
Step 3: Step 3: DataSet
Dataset: this code when we run it , we need to enter user id number after entering the id number it will start taking pictures and save it in the file named dataset , you can chose the number of pictures taken and the frame size
the number of pictures taken in the code is 30
the fame size is 1.3
Step 4: Step 4: Algorithms
this code transfer the pictures that has been saved in the dataset file to algorithms so that the system can identifies the data.
Step 5: Step 5:Face Recognition
We added the facial recognition code. It is a code that recognizes the front face by comparing the images saved in the data set file and the currently captured images, and the process is done through the image conversion code into the algorithm's measurements and showing the saved name in case of finding a match. if it didn't find a match it will say unknown.
Note:
In the code we can change the id number to the real names of the person but the name need to be connected to the id number in the dataset
example:
in the code of the dataset we will enter user_1 but in the face recognition code we delete id_1 and wrote Mohammad to show it on the frame .
extra note:
We can adjust the sensitivity of the camera and how many time checking.
Step 6: Step 6: Text to Speech
here we add two libraries and they are (pyttsx3&espeak).We add text to speech to say the names.
we had some problems in the library of speck but the project supervisor helped us with it
Step 7: Step 7: Adding a Second Camera and the Text to Speech
in this step we add the codes of the second camera and the text to speech and pushbuttons
Step 8: Step 8:Adding the Codes and the Database
we add CSV library for the database and its run with the LibreOffice
and this is the final project video
Step 9: Thanks to Dr.Jabber
نشكر الله ثم الدكتور جابر على دعمه ورعايته لهذا المشروع
واالله ولي التوفيق
