Introduction: AtticTemp - Temperature / Climate Logger
High tolerance temperature gauge and climate logger for your attic or other outdoor structures
Step 1: Flashing RaspberriPi Hard Disk / Install Required Software (Using Ubuntu Linux)
Download "RASPBIAN JESSIE LITE" https://www.raspberrypi.org/downloads/raspbian/
Create your new hard disk for DashboardPI
Insert the microSD to your computer via USB adapter and create the disk image using the dd command
Locate your inserted microSD card via the df -h command, unmount it and create the disk image with the disk copy dd command
$ df -h /dev/sdb1 7.4G 32K 7.4G 1% /media/XXX/1234-5678
$ umount /dev/sdb1
Caution: be sure the command is completely accurate, you can damage other disks with this command
if=location of RASPBIAN JESSIE LITE image file of=location of your microSD card
$ sudo dd bs=4M if=/path/to/raspbian-jessie-lite.img of=/dev/sdb (note: in this case, it's /dev/sdb, /dev/sdb1 was an existing factory partition on the microSD)
Setting up your RaspberriPi
Insert your new microSD card to the raspberrypi and power it on with a monitor connected to the HDMI port
Login
user: pi pass: raspberry
Change your account password for security
sudo passwd pi
Enable RaspberriPi Advanced Options
sudo raspi-config
Choose: 1 Expand File System
9 Advanced Options
A2 Hostname change it to "AtticTemp"
A4 SSH Enable SSH Server
A7 I2C Enable i2c interface
Enable the English/US Keyboard
sudo nano /etc/default/keyboard
Change the following line: XKBLAYOUT="us"
Reboot PI for Keyboard layout changes / file system resizing to take effect
$ sudo shutdown -r now
Auto-Connect to your WiFi
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Add the following lines to have your raspberrypi automatically connect to your home WiFi (if your wireless network is named "linksys" for example, in the following example)
network={ ssid="linksys" psk="WIRELESS PASSWORD HERE" }
Reboot PI to connect to WiFi network
Now that your PI is finally on the local network, you can login remotely to it via SSH. But first you need to get the IP address it currently has.
$ ifconfig Look for "inet addr: 192.168.XXX.XXX" in the following command's output for your PI's IP Address
Go to another machine and login to your raspberrypi via ssh
$ ssh pi@192.168.XXX.XXX
Start Installing required packages
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get install vim git python-requests python-smbus i2c-tools python-imaging python-smbus build-essential python-dev rpi.gpio python3 python3-pip libi2c-dev
Update local timezone settings
$ sudo dpkg-reconfigure tzdata
select your timezone using the interface
Setup the simple directory l command [optional]
$ vi ~/.bashrc
add the following line:
$ alias l='ls -lh'
$ source ~/.bashrc
Fix VIM default syntax highlighting [optional]
$ sudo vi /etc/vim/vimrc
uncomment the following line:
syntax on
Step 2: Clone Project / Install Software Drivers
Clone Project repository
$ cd ~
$ git clone https://github.com/khinds10/AtticTemp.git
DHT22 Install
$ cd ~
$ git clone https://github.com/adafruit/Adafruit_Python_DHT.g...
$ cd Adafruit_Python_DHT/
$ sudo python setup.py install
$ sudo python ez_setup.py
$ cd examples/
$ vi simpletest.py
sensor = Adafruit_DHT.DHT22
Comment the line out
pin = 'P8_11'
Uncomment the line and change the pin number to 16
pin = 18
Run the test
python simpletest.py
You should see a metric reading of Temp and Humidity displayed on the command line.
SSD1306 Install
Extract drivers/SSD1306.zip to the project folder
Install the Driver
$ cd ssd1306/
Confirm your device registers, usually it's \0x3c on the i2c bus
$ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f 00:
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Run the demo to confirm your display is in working order
$ cd examples/ $ python demo.py
Step 3: Supplies Needed
RaspberriPi Zero
DHT22 temperature-humidity sensor
0.96" I2C IIC SPI Serial 12864 OLED LCD LED White Display Module
2.4" 400x240 16:9 Serial:UART/I2C/SPI TFT Touchscreen Display
Step 4: Wire the Device
SSD1306 Display
GND -> GND
DATA -> SDA
CLK -> SCL
VCC -> 3V
Digole Display
GND -> GND
DATA -> SDA
CLK -> SCL
VCC -> 3V
DHT22 Humidistat
VCC -> 5V
GND -> GND
DATA -> GPIO 18 / PIN 12
Step 5: Build the Device
Cut Plexiglass to fit the front of the device under the 3D printed frame
Mount the glass with screws through the 3D printed frame
Step 6: Build the Device (cont...)
Hot Glue Components against the front panel
Wire Unit inside
Mount the back and it should be ready to go
Step 7: Configure Application to Run Correctly in Settings.py Config File
Find the file settings.py and adjust to your current settings
# forecast.io API key for local weather information
weatherAPIURL = 'https://api.forecast.io/forecast/'
weatherAPIKey = 'YOUR API KEY FOR FORECAST.IO'
# optional for running the remote temp/humidity logger
deviceLoggerAPI = 'mydevicelogger.com'
# search google to get the Latitude/Longitude for your home location
latitude = 41.4552578
longitude = -72.1665444
Step 8: Setup Scheduled Scripts
$ crontab -e
Add the following lines:
*/7 * * * * python /home/pi/AtticTemp/displays.py
OPTIONAL: Temp Logger to API script each 10 minutes
$ crontab -e
*/10 * * * * python /home/pi/EnvironmentClock/temp-check.py
Step 9: OPTIONAL: Creating Your Own Weather Images to Render on the Display
Upload your own 128x128 file to the following URL:
http://www.digole.com/tools/PicturetoC_Hex_converter.php
Choose your image file to upload, add what size you want it to be on the screen (Width/Height)
Select "256 Color for Color OLED/LCD(1 byte/pixel)" in the "Used for" dropdown
Obtain the hex output.
Add the hex output to a display/build/ header (.h) file, use the other ones as guides for syntax.
Include the new file in the digole.c file #include "myimage.h
Include a new command line hook to your image file in the. Note: the command below is saying draw your image at position 10 pixels over 10 pixels down. You can change it to different X,Y coordinates, you can also change the values 128,128 to whatever size your new image actually is.
} else if (strcmp(digoleCommand, "myimage") == 0) { drawBitmap256(10, 10, 128, 128, &myimageVariableHere,0); // myimageVariableHere is defined in your (.h) file }
Now rebuild (ignore the errors) below to have your new image render with the following command.
$ ./digole myimage
Re-Building [Included] Digole Display Driver for your optional changes
$ cd display/build
$ gcc digole.c
$ mv a.out ../../digole
$ chmod +x ../../digole
