Introduction: Auduino (Lo-fi Synth for Arduino)
Sketch created by Peter Knight, Tinker.it http://tinker.it.
For more information please visit the website.
I hope you are already familiarized with the arduino environment, if not get an arduino and check for more information at arduino.cc
Step 1: Materials
- X5 5K Potentiometer
- A breadboard.
- An 8 Ohm speaker or a jack.
This you'll probably have laying around and will be needed:
- Various jumpers
- X1 Arduino (I am using Arduino Uno R2)
Optional:
- X5 Knob (For the Pots)
Step 2: The Pots
So the potentiometers go on the breadboard, I couldn't find the best stop for them because their back part wouldn't fit. But I managed to squeeze them in at the last row and I flexed the breadboard as shown in the picture.
Basically all there positive leads are connected to 5V and all there negatives are going to ground. And the pots middle lead goes to an analog pin on the arduino.
Pot 1 goes to analog 4.
Pot 2 goes to analog 3.
Pot 3 goes to analog 2.
Pot 4 goes to analog 1.
Pot 5 goes to analog 0.
The pictures show how to connect the jumpers very clear.
Step 3: The Speaker
I used a speaker but you can use a jack and connect it to the same arduino pins.
Speaker must go connect to digital 3 on the arduino. And negative to ground...
Step 4: The Code
You can download the sketch here or you can just paste the code below on your arduino program and start to upload.
// Auduino, the Lo-Fi granular synthesiser
// by Peter Knight, Tinker.it http://tinker.it
// Help: http://code.google.com/p/tinkerit/wiki/Auduino
// More help: http://groups.google.com/group/auduino
// Analog in 0: Grain 1 pitch
// Analog in 1: Grain 2 decay
// Analog in 2: Grain 1 decay
// Analog in 3: Grain 2 pitch
// Analog in 4: Grain repetition frequency
// Digital 3: Audio out (Digital 11 on ATmega8)
// Changelog:
// 19 Nov 2008: Added support for ATmega8 boards
// 21 Mar 2009: Added support for ATmega328 boards
// 7 Apr 2009: Fixed interrupt vector for ATmega328 boards
// 8 Apr 2009: Added support for ATmega1280 boards (Arduino Mega)
#include <avr/io.h>
#include <avr/interrupt.h>
uint16_t syncPhaseAcc;
uint16_t syncPhaseInc;
uint16_t grainPhaseAcc;
uint16_t grainPhaseInc;
uint16_t grainAmp;
uint8_t grainDecay;
uint16_t grain2PhaseAcc;
uint16_t grain2PhaseInc;
uint16_t grain2Amp;
uint8_t grain2Decay;
// Map Analogue channels
#define SYNC_CONTROL (4)
#define GRAIN_FREQ_CONTROL (0)
#define GRAIN_DECAY_CONTROL (2)
#define GRAIN2_FREQ_CONTROL (3)
#define GRAIN2_DECAY_CONTROL (1)
// Changing these will also requires rewriting audioOn()
#if defined(__AVR_ATmega8__)
// On old ATmega8 boards.
// Output is on pin 11
#define LED_PIN 13
#define LED_PORT PORTB
#define LED_BIT 5
#define PWM_PIN 11
#define PWM_VALUE OCR2
#define PWM_INTERRUPT TIMER2_OVF_vect
#elif defined(__AVR_ATmega1280__)
// On the Arduino Mega
// Output is on pin 3
#define LED_PIN 13
#define LED_BIT 7
#define PWM_PIN 3
#define PWM_VALUE OCR3C
#define PWM_INTERRUPT TIMER3_OVF_vect
#else
// For modern ATmega168 and ATmega328 boards
#define PWM_PIN 3
#define PWM_VALUE OCR2B
#define LED_PIN 13
#define LED_BIT 5
#endif
// Smooth logarithmic mapping
uint16_t antilogTable[] = {
64830,64132,63441,62757,62081,61413,60751,60097,59449,58809,58176,57549,56929,56316,55709,55109,
54515,53928,53347,52773,52204,51642,51085,50535,49991,49452,48920,48393,47871,47356,46846,46341,
45842,45348,44859,44376,43898,43425,42958,42495,42037,41584,41136,40693,40255,39821,39392,38968,
38548,38133,37722,37316,36914,36516,36123,35734,35349,34968,34591,34219,33850,33486,33125,32768
uint16_t mapPhaseInc(uint16_t input) {
return (antilogTable[input & 0x3f]) >> (input >> 6);
// Stepped chromatic mapping
uint16_t midiTable[] = {
17,18,19,20,22,23,24,26,27,29,31,32,34,36,38,41,43,46,48,51,54,58,61,65,69,73,
77,82,86,92,97,103,109,115,122,129,137,145,154,163,173,183,194,206,218,231,
244,259,274,291,308,326,346,366,388,411,435,461,489,518,549,581,616,652,691,
732,776,822,871,923,978,1036,1097,1163,1232,1305,1383,1465,1552,1644,1742,
1845,1955,2071,2195,2325,2463,2610,2765,2930,3104,3288,3484,3691,3910,4143,
4389,4650,4927,5220,5530,5859,6207,6577,6968,7382,7821,8286,8779,9301,9854,
10440,11060,11718,12415,13153,13935,14764,15642,16572,17557,18601,19708,20879,
22121,23436,24830,26306
uint16_t mapMidi(uint16_t input) {
return (midiTable[(1023-input) >> 3]);
// Stepped Pentatonic mapping
uint16_t pentatonicTable[54] = {
0,19,22,26,29,32,38,43,51,58,65,77,86,103,115,129,154,173,206,231,259,308,346,
411,461,518,616,691,822,923,1036,1232,1383,1644,1845,2071,2463,2765,3288,
3691,4143,4927,5530,6577,7382,8286,9854,11060,13153,14764,16572,19708,22121,26306
uint16_t mapPentatonic(uint16_t input) {
uint8_t value = (1023-input) / (1024/53);
return (pentatonicTable[value]);
void audioOn() {
// ATmega8 has different registers
TCCR2 = _BV(WGM20) | _BV(COM21) | _BV(CS20);
TIMSK = _BV(TOIE2);
TCCR3A = _BV(COM3C1) | _BV(WGM30);
TCCR3B = _BV(CS30);
TIMSK3 = _BV(TOIE3);
#else
// Set up PWM to 31.25kHz, phase accurate
TCCR2A = _BV(COM2B1) | _BV(WGM20);
TCCR2B = _BV(CS20);
TIMSK2 = _BV(TOIE2);
#endif
void setup() {
pinMode(PWM_PIN,OUTPUT);
audioOn();
pinMode(LED_PIN,OUTPUT);
void loop() {
// The loop is pretty simple - it just updates the parameters for the oscillators.
// Avoid using any functions that make extensive use of interrupts, or turn interrupts off.
// They will cause clicks and poops in the audio.
// Smooth frequency mapping
//syncPhaseInc = mapPhaseInc(analogRead(SYNC_CONTROL)) / 4;
// Stepped mapping to MIDI notes: C, Db, D, Eb, E, F...
//syncPhaseInc = mapMidi(analogRead(SYNC_CONTROL));
// Stepped pentatonic mapping: D, E, G, A, B
syncPhaseInc = mapPentatonic(analogRead(SYNC_CONTROL));
grainPhaseInc = mapPhaseInc(analogRead(GRAIN_FREQ_CONTROL)) / 2;
grainDecay = analogRead(GRAIN_DECAY_CONTROL) / 8;
grain2PhaseInc = mapPhaseInc(analogRead(GRAIN2_FREQ_CONTROL)) / 2;
grain2Decay = analogRead(GRAIN2_DECAY_CONTROL) / 4;
SIGNAL(PWM_INTERRUPT)
uint8_t value;
uint16_t output;
syncPhaseAcc += syncPhaseInc;
if (syncPhaseAcc < syncPhaseInc) {
// Time to start the next grain
grainPhaseAcc = 0;
grainAmp = 0x7fff;
grain2PhaseAcc = 0;
grain2Amp = 0x7fff;
LED_PORT ^= 1 << LED_BIT; // Faster than using digitalWrite
// Increment the phase of the grain oscillators
grainPhaseAcc += grainPhaseInc;
grain2PhaseAcc += grain2PhaseInc;
// Convert phase into a triangle wave
value = (grainPhaseAcc >> 7) & 0xff;
if (grainPhaseAcc & 0x8000) value = ~value;
// Multiply by current grain amplitude to get sample
output = value * (grainAmp >> 8);
// Repeat for second grain
value = (grain2PhaseAcc >> 7) & 0xff;
if (grain2PhaseAcc & 0x8000) value = ~value;
output += value * (grain2Amp >> 8);
// Make the grain amplitudes decay by a factor every sample (exponential decay)
grainAmp -= (grainAmp >> 8) * grainDecay;
grain2Amp -= (grain2Amp >> 8) * grain2Decay;
// Scale output to the available range, clipping if necessary
output >>= 9;
if (output > 255) output = 255;
// Output to PWM (this is faster than using analogWrite)
PWM_VALUE = output;
Step 5: Wrap Up
Some extras would be adding knobs. :)
Any progress or anything for the style, I will write down here.
Write in the comments what you did or if you have any questions.
Tobias
Plus a video I made so you can listen to the sounds of this synth:
Try to make a shield version! :)
1 Person Made This Project!
- leeseibert made it!
30 Comments
2 years ago
can anyone plzzzz HELP!! From the moment i connect the last pot to GND and 5v my arduino just stops working, no power, NOTHING!!! ... i really have no clue what can be wrong :/
4 years ago
Hi ! pots going in serial or parallel ? only works 1 at time.
4 years ago
Apologies I'm a noob whatsingnal are you sending to the ardunio from you compute?
Cheers
4 years ago
I could use a potentiometer of 10k instead of 5k (it's just that I have here)?
Reply 4 years ago
From the man himself:
https://groups.google.com/forum/#!topic/auduino/Da...
Anything between 1K and 50K. I've built two of these and the only difference the resistance makes is the range of control. 5K to 10K is a pretty good level of control. Any higher and you'll find yourself making tiny little movements and skipping over large chunks of the scale. I may try one of those multi-turn pots in the future if I'm ever bored enough.
Reply 4 years ago
Thanks, man! @matsugawa ((:
5 years ago
For some reason I can only get one knob to do anythin of the 4, anyone else with this issue?
Reply 4 years ago
Same issue. I can only get the frequency swipe but none of the others work or seem to do anything. I've tried every wire combination but only one controls. Did you figure this out?
5 years ago
I have Arduino Leonardo and Arduino IDE 1.6.7 and i have following error:
'TCCR2A' was not declared in this scope (line 134)
Reply 4 years ago
The Leonardo has no Timer2 so most sketches you find on the internet including this one that use this Timer won't work.
4 years ago
Huge fan of this project. Question though, if I wanted to upgrade the speaker, not really aiming for sound quality as much as volume, how would I go about doing so? As you can tell I'm quite new. Really appreciate any tips though.
4 years ago
Do you think this would work with 100k ohm pots?
5 years ago
my parts are coming soon!??
6 years ago on Introduction
I love this project. It's one of the first things I built when I got my Arduino. I recently added basic vactrol based CV inputs so I could use the granular synth with my Lunetta CMOS based noise machine.
https://www.instructables.com/id/Adding-CV-inputs-t...
I entered my CV version of the Auduino in the Remix contest. I gave you all the credit for the original project of course.
Thanks- this really has become one of my favorite instruments. When my friend the synth snob heard it for the first time he said 'wow, it's about time you built a real analog synth'. When I opened the box and showed him the lone Arduino board he turned red.
7 years ago on Introduction
My potentiometers don't fit into my breadboard, so atm i have them taped to the jumper wires, and the wires are plugged into the breadboard, is there a better way?
Reply 6 years ago
You can just solder some wires/leads onto the pits too
You could buy trimmers, they are small ones which go on for pcb mount.
https://en.wikipedia.org/wiki/Potentiometer
May be better to use a Due since the chip has 10-12-bit ADC/DAC's
Does this work with an Arduino Uno R3?
Yes, there shouldn't be any trouble...
