Introduction: Austin's Stool
Make a small stool using cardboard as a step to reach higher shelves at home or to just sit on it.
- Cardboard
- Masking Tape
- Scissors
- Cardboard Cutter
Step 1: Build the Legs of the Stool
Cut out a piece of cardboard of around 15cm in height and fold it into a triangular tube. Secure it with tape and repeat the step to create 4 legs for the stool.
Step 2: Cut Out the Wide Base for the Stool
Cut out a wide piece of cardboard of aroun 35cm X 35cm.
Step 3: Assemble Together With Tape
Stick the 4 legs of the stool to the bottom of the base with masking tape.
Step 4: Test Out the Stability
Test out the stool stability by sitting or steeping on it. If it is not stable enough, add on the thickness of the base or the legs of the stool.
