Introduction: Auto Heater: Because Manual Heating Is for Cavemen! 🔥
Are you tired of waiting for your room to heat up like a frozen turkey in a microwave? Well, worry no more! Presenting the Auto Heater 3000, a device so smart it could probably pass a kindergarten IQ test. It reads the temperature and activates a servo to control a heater when things get chilly—or in this case, when it doesn't meet your royal warmth standards.
Before we get started, let me tell you, I first built this digitally on Wowki (a microcontroller simulation platform, because why risk real-life failure when you can fail virtually first?). Once it worked without setting my imaginary house on fire, I took the plunge and built it for real. Spoiler alert: It works!
Oh, and a fun fact about me: I’m chronically sick kid, and when it gets too cold at night, I’m definitely not awake enough to turn on the heater manually. So, automation isn’t just cool—it’s survival! 💀🔥
Microcontroller (Raspberry Pi Pico, ESP8266, etc.) – Your obedient electronic minion
DHT Sensor (DHT22 preferred) – Because we need temperature data, not blind guesses
Servo Motor (or a relay but I'm too scared of electricity)– The hand of automation!
OLED Display (Adafruit SSD1306) – To flex your temperature readings
Jump Wires – The spaghetti that holds it all together
Power Supply (5V) – Because magic needs electricity
Breadboard (Optional) – For that sweet prototyping experience
Step 1:
Load up Wowi.com and select Pi Pico
Step 2:
Select the Pi Pico Starter template
Step 3:
Click the plus button and add the following components
ssd1306
Servo
DHT22
Step 4: Wiring It Up Like a Pro 🎛️
Pin Connections:
All VCC/V+ pins to VBus
All ground pins to anywhere on the board where it says GND.0+n
DHT Sensor(SDA)
GP28
Servo Motor(PWM)
GP2
OLED Display
SDA (GP0), SCL (GP1)
Connect everything as neatly as a secret agent defusing a bomb, or as chaotically as your earphone wires in your pocket. Your choice.
Step 5: Code Like a Legend 💻
Here’s where the magic happens! We use the DHT sensor library to read the temperature and an OLED screen library to display it. If the temperature drops below a certain point (set by you, the master of warmth), the servo activates the heater.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <DHT.h>
#include <Servo.h>
#define DHTPIN 28
#define DHTTYPE DHT22
#define SERVO_PIN 2
#define OLED_RESET -1
Adafruit_SSD1306 display(128, 64, &Wire, OLED_RESET);
DHT dht(DHTPIN, DHTTYPE);
Servo heaterServo;
void setup() {
Serial.begin(9600);
dht.begin();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
heaterServo.attach(SERVO_PIN);
display.clearDisplay();
display.display();
void loop() {
float temp = dht.readTemperature();
if (isnan(temp)) {
Serial.println("Failed to read DHT sensor!");
return;
display.setCursor(0, 10);
display.setTextSize(2);
display.setTextColor(SSD1306_WHITE);
display.print("Temp: ");
display.print(temp);
display.print(" C");
display.display();
if (temp < 30) { // Adjust this threshold
heaterServo.write(90); // Heater ON
} else {
heaterServo.write(0); // Heater OFF
delay(2000);
Step 6: Try It Out
Test it out by pressing play
PS if you don't want to do all that use my code https://wokwi.com/projects/424455583048128513
Step 7: Wire It Up IRL
Now wire it up exactly as you did in the simulator
Step 8: Flash the Code Using Arduino IDE
Here's a tutorial in case you are having some trouble
Tip download all libraries mentioned in the code
https://www.youtube.com/watch?v=RQRQvjIBbUo
Step 9: Testing & Troubleshooting 🛠️
Doesn’t turn on? Check if you wired it like a normal person and not like an angry octopus.
Temperature isn’t reading? Make sure the DHT sensor is properly connected and powered.
Servo isn’t moving? Give it a pep talk (or check its power and connections).
Step 10: Tape It Up
Attach the servo to the switch, ensuring that when it gets too cold, it will turn on your heater, and switch it off when it gets too hot
Step 11: Sit Back and Enjoy! ☕🔥
Congratulations! You have successfully created an automatic heater system that probably works better than your landlord’s heating system.
Now, bask in the warmth of automation and flex your project to your friends. Bonus points if you name it something ridiculous like "Heat-O-Matic 9000."
Happy coding and stay warm! 😆🔥
