Introduction: Automata Project by Ethan Pullaro
You will need
3 big straws
3 smaller straws
1 box
Step 1: Step 1: Making First Holes in the Box
First you will make two holes on either side of the box
Step 2: Step 2: Putting the Straw Through
Next you take two straws tape them together and put them the two holes you just created
Step 3: Step 3: More Holes
After that, you will make holes on the top of the box where the straws will be moving holding the items, in this case boats
Step 4: Step 4: Putting the Straws In
You will insert the straws through the top hole so they line up and touch the big straws on the bottom
Step 5: Step 5: Adding the Movers
You will cut up straws into pieces and put tape on them to put on the bigger straw this will hit the smaller straws and move the items
Step 6: Step 6: Lining Everything Up
Make sure the movers are secure on the big straws and make sure they can hit the smaller straws
Step 7: Step 7: Cutting the Straws to the Right Size
Cut the straws so they are only showing a bit out of the box
Step 8: Step 8: Finishing Up
Add things to the box to make it look nice and add things onto the straws so they look like they are moving in the background
