Automata (motorcycle) By maraya23 in CraftCardboard51432Introduction: Automata (motorcycle)I will show you how to make a cardboard motorcyle that moves.Step 1: Cut Three Evenly Spaced Slits Into a Piece of Cardboard.Step 2: Fold the Cardboard Into a Box and Secure With Tape.Step 3: Make a Hole in the Side of the Box.Step 4: Cut a Dowel to the Desired Length and Make Sure That It Fits in the Hole.Step 5: If Desired, Tape a Small Strip of Cardboard to the Dowel to Make a Handle.Step 6: Next, Cut Two Cricles From Cardboard and Poke a Hole at the Center of One of Them.Step 7: Cut a Shorter Dowel and Make Sure That It Fits the Hole in the Wheel.Step 8: Take Two Eye Screws and Screw Them Into the Top of the Box. Then Cut a Hole in the Top of the Box.Step 9: Cut the Frame of the Motorcycle Out of Cardboard.Step 10: Next, Find a Washer Big Enough to Fit the Dowel and Glue It to the Bike. Also Glue on the Front Wheel.Step 11: Finally, Put the Rubberband Over Both Dowels and Slide the Washer Over the Dowel So That It Sits Next to the Back Wheel.AttachmentsAutomata (motorcycle) - Step #11DownloadStep 12: Crank the Dowel and the Back Wheel Should Spin.
