Introduction: Automated Plant Watering System
An automated watering system using a soil moisture sensor and Arduino is an efficient way to ensure plants receive the right amount of water without manual intervention. This system is particularly useful for home gardens, greenhouses, and agricultural applications where consistent watering is necessary for plant health. The project will utilize two buttons, each representing different plants and their moisture thresholds. It will also utilize a soil moisture sensor to detect moisture levels in the soil, an Arduino microcontroller to process the data, and a water pump to supply water as needed. When the soil moisture falls below the predefined threshold, the Arduino activates the pump to water the plants. Once the desired moisture level is reached, the system stops the water flow, conserving water and preventing overwatering.
- 1 x Arduino Uno REV3 [A000066]
- 1 x ELEGOO 3pcs Breadboard 830 Point Solderless Prototype PCB Board Kit for Arduino Proto Shield Distribution Conn
- 2 x buttons from Gikfun 12x12x7.3 mm Tact Tactile Push Button Momentary SMD PCB Switch with Cap for Arduino (Pack of 25pcs)
- 1 x HiLetgo 5pcs LM393 3.3V-5V Soil Moisture Detect Sensor Soil Moisture Sensor Soil Hygrometer Detection for Arduino Automatic Watering System Robot Smart car
- 1 x 4PCS DC 3V 5V Micro Submersible Mini Water Pump for Aquariums Fish Tank Pond Fountain Hydroponics Garden with 2M Flexible Tube Water Pipe
- 1 x AEDIKO 4pcs DC 5V Relay Module 1 Channel Relay Switch Relay Board with Optocoupler Isolation Support High or Low Level Trigger
- 9V Battery
- Wires
- Water Container
- Plant
Step 1: Collect Your Supplies
Arduino Board (Uno) – The microcontroller that processes sensor data and controls the pump.
Breadboard – Used for circuit connections and stability.
Buttons – Used to determine what plant is being watered.
Soil Moisture Sensor – Measures the moisture level in the soil and sends data to the Arduino.
Water Pump (DC or Submersible Pump) – Supplies water to the plants when activated.
Tubing – Delivers water from the pump to the plants.
Relay Module – Acts as a switch to control the pump based on Arduino signals.
Wires – Used for connecting components.
Power Supply (9V Battery) – Provides power to the relay.
Water Reservoir – Holds water for irrigation.
Plant - is the test subject for the project.
Step 2: Setting Up the Connections
Moisture Sensor:
Analog Output (AO) to Analog Pin A0 on Arduino.
VCC to 5V on Arduino.
GND to GND on Arduino.
Relay Module:
IN (control pin) to Digital Pin 7 on Arduino.
VCC and GND powered from the 9V battery (via relay's own terminals).
Buttons:
One button connects GND to Digital Pin 2 (yellow wire).
Second button connects GND to Digital Pin 3 (green wire).
Pump:
The pump (white box) is powered by the relay:
One wire from the pump goes directly to battery positive.
The other goes through the NO (Normally Open) terminal of the relay.
When the relay is triggered (closed), the circuit completes and the pump runs.
Step 3: Physical Set Up of the System
Once the connections are set up, the plants, water, and tubing can be added. The pump is submerged into the water container with a tube connected to it. This tube is then ran to the soil of the plant in which the moisture sensor is in.
Step 4: Develope the Code
// Pin configuration
const int moistureSensorPin = A0; // Analog pin for soil moisture sensor
const int relayPin = 7; // Digital pin connected to the relay module
const int buttonPinA = 5; // Digital pin for button A (Plant A)
const int buttonPinB = 6; // Digital pin for button B (Plant B)
// Plant profiles
struct PlantProfile {
int wetThreshold; // Moisture value above which pump should turn ON
int dryThreshold; // Moisture value below which pump should turn OFF
// Define two plant profiles with respective moisture thresholds
PlantProfile plantA = {1000, 500}; // Profile A with high wet threshold
PlantProfile plantB = {850, 600}; // Profile B with moderate thresholds
PlantProfile selectedProfile; // Variable to store currently selected profile
bool profileSelected = false; // Flag to check if a profile has been chosen
bool pumpOn = false; // State of the pump
void setup() {
pinMode(moistureSensorPin, INPUT); // Set sensor pin as input
pinMode(relayPin, OUTPUT); // Set relay pin as output
pinMode(buttonPinA, INPUT_PULLUP); // Set button A pin as input with pull-up resistor
pinMode(buttonPinB, INPUT_PULLUP); // Set button B pin as input with pull-up resistor
digitalWrite(relayPin, LOW); // Ensure pump is OFF at startup
Serial.begin(9600); // Start serial communication
Serial.println("System started.");
Serial.println("Press Button A or B to select plant profile...");
void loop() {
if (!profileSelected) { // Wait for user to select a plant profile
waitForProfileSelection();
return;
int moistureLevel = analogRead(moistureSensorPin); // Read moisture level from sensor
Serial.print("Soil Moisture Level: ");
Serial.println(moistureLevel);
// If soil is too dry and pump is OFF, turn pump ON
if (moistureLevel < selectedProfile.dryThreshold && !pumpOn) {
Serial.println("Soil is wet. Turning pump OFF.");
pumpOn = true;
// If soil is wet enough and pump is ON, turn pump OFF
else if (moistureLevel > selectedProfile.wetThreshold && pumpOn) {
Serial.println("Soil is dry. Turning pump ON.");
digitalWrite(relayPin, HIGH);
pumpOn = false;
delay(2000); // Wait for 2 seconds before next reading
void waitForProfileSelection() {
// Check if Button A is pressed
if (digitalRead(buttonPinA) == LOW) {
delay(50); // Debounce delay
selectedProfile = plantA;
profileSelected = true;
printSelectedProfile("Plant A");
// Check if Button B is pressed
else if (digitalRead(buttonPinB) == LOW) {
selectedProfile = plantB;
printSelectedProfile("Plant B");
void printSelectedProfile(const char* plantName) {
Serial.print("Selected profile: ");
Serial.println(plantName);
Serial.print(" Dry threshold: ");
Serial.println(selectedProfile.dryThreshold);
Serial.print(" Wet threshold: ");
Serial.println(selectedProfile.wetThreshold);
Step 5: Video of Project
https://mediahub.ku.edu/media/t/1_vwrst5yn
