Introduction: VBscript to Automate Convesion To/from STL, STP, DAE and IGES Files Via FreeCAD
About: 78 years old, retired with much time to spend.
Finally I found a way to do conversions between different 3D files without wasting time!
Link to download the script:
https://mega.nz/file/O4kWVLCC#p7L71F6waeni2dAxE2qLWPrKde0UxHMrY8qka0gj65g
Step 1: My Goal
I use Tinkercad to realize my 3D projects, so I make intensive use of STL files, but I was asked many times to render my STL in STEP, IGES or DAE format.
That's really a tedious work, due to large number of items to process.
To convert STL to other file type I use FreeCAD, whose flexibility let me make several types of conversion between formats, but it's a time consuming operation, of course.
I decided to face the problem one time for all and write down some script to automatize the conversions.
You can place this script wherever you want in your disk.
Step 2: The VBS Script
' Created by Francesco Francescangeli
' 2021-10-18
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objShell = CreateObject("WScript.Shell")
Set objPopup = CreateObject("WScript.Shell")
Set Arg = Wscript.Arguments
Const ForReading = 1, ForWriting = 2
const ShowWindow = 1, DontShowWindow = 0, WaitUntilFinished = true, DontWaitUntilFinished = false
INsupported = "STL,STP,DAE,IGES"
OUTsupported = INsupported
' Check all is OK
If Arg.count < 4 Then
 wscript.echo "Missing parameters!" & vbCrLf & "Syntax:" & vbCrLf & "CONVERT.VBS [INtype] [OUTtype] [Full INpath] [Full OUTpath]"
 WScript.Quit
End If
INfiletype = UCase(Arg(0))
OUTfiletype = UCase(Arg(1))
INdir = Arg(2)
INdir = Replace(INdir, "\", "/")
OUTdir = Arg(3)
OUTdir = Replace(OUTdir, "\", "/") & "/"
Set objFolder = objFSO.GetFolder(INdir)
numFiles = objFolder.Files.Count
If numFiles = 0 Then
 wscript.echo "Input directory empty!"
 WScript.Quit
End If
If INfiletype = OUTfiletype Then
 wscript.echo "IN and OUT file format is identical!"
 WScript.Quit
End If
If InStr(INsupported, INfiletype) = 0 Or InStr(OUTsupported, OUTfiletype) = 0 Then
 wscript.echo "Input file type not supported!"
 WScript.Quit
End If
Set allFiles = objFolder.Files
numTot = 0
For Each objFile in allFiles
 If UCase(objFSO.GetExtensionName(objFile.Name)) = INfiletype Then
  numTot = numTot + 1
 End If
Next
If numTot = 0 Then
 wscript.echo "No " & INfiletype & " file found!"
 WScript.Quit
End If
'Functions
Function ControlName(FileName)
 If IsNumeric(Mid(FileName,1,1)) Then
  ControlName = "_" & Mid(FileName,2)
 Else
  ControlName = FileName
 End If
End Function
Function sendIN(str)
 MsgLine = Trim(str)
 x = objPopup.Popup(MsgLine, 3, "Work in progress" , 64)
End Function
Function sendEND(str)
 MsgLine = Trim(str)
 x = objPopup.Popup(MsgLine, 10, "Job completed!" , 64)
End Function
Function FileConv(extIN, extOUT, nameIN, nameOUT, namePart, path)
 FileConv = false
 If objFSO.FileExists(nameOUT) Then
  objFSO.DeleteFile(nameOUT)
 End If
 Set filetxt = objFSO.CreateTextFile(ConvScript, ForWriting)
 Select Case extIN
  Case "STL"
   Select Case extOUT
    Case "STP"
     filetxt.WriteLine("import FreeCAD, Mesh, Part, Import")
     filetxt.WriteLine("Mesh.open('" & nameIN & "')")
     filetxt.WriteLine("FreeCAD.getDocument('Unnamed').addObject('Part::Feature', '" & namePart & "001')")
     filetxt.WriteLine("__shape__ = Part.Shape()")
     filetxt.WriteLine("__shape__.makeShapeFromMesh(FreeCAD.getDocument('Unnamed').getObject('" & namePart & "').Mesh.Topology, 0.1)")
     filetxt.WriteLine("FreeCAD.getDocument('Unnamed').getObject('" & namePart & "001').Shape = __shape__")
     filetxt.WriteLine("FreeCAD.getDocument('Unnamed').getObject('" & namePart & "001').purgeTouched()")
     filetxt.WriteLine("del __shape__")
     filetxt.WriteLine("__objs__ = []")
     filetxt.WriteLine("__objs__.append(FreeCAD.getDocument('Unnamed').getObject('" & namePart & "001'))")
     filetxt.WriteLine("Import.export(__objs__, '" & path & nameOUT & "')")
     filetxt.WriteLine("del __objs__")
    Case "DAE"
     filetxt.WriteLine("import FreeCAD, Mesh, importDAE")
     filetxt.WriteLine("Mesh.open(u'" & nameIN & "')")
     filetxt.WriteLine("__objs__.append(FreeCAD.getDocument('Unnamed').getObject('" & namePart & "'))")
     filetxt.WriteLine("importDAE.export(__objs__, u'" & path & nameOUT & "')")
    Case "IGES"
     filetxt.WriteLine("import FreeCAD, Mesh, Part")
     filetxt.WriteLine("__shape__=Part.Shape()")
     filetxt.WriteLine("FreeCAD.getDocument('Unnamed').getObject('" & namePart & "001').Shape=__shape__")
     filetxt.WriteLine("Part.export(__objs__, u'" & path & nameOUT & "')")
   End Select
  Case "STP"
   Select Case extOUT
    Case "STL"
     filetxt.WriteLine("shape = Part.Shape()")
     filetxt.WriteLine("shape.read('" & nameIN & "')")
     filetxt.WriteLine("doc = App.newDocument(""Doc"")")
     filetxt.WriteLine("pf = doc.addObject(""Part::Feature"",""MyShape"")")
     filetxt.WriteLine("pf.Shape = shape")
     filetxt.WriteLine("Mesh.export([pf], " & chr(34) & path & nameOUT & chr(34) & ")")
    Case "DAE"
     filetxt.WriteLine("import FreeCAD, Mesh, Part, importDAE")
     filetxt.WriteLine("importDAE.export([pf], " & chr(34) & path & nameOUT & chr(34) & ")")
    Case "IGES"
     filetxt.WriteLine("import FreeCAD, Part")
     filetxt.WriteLine("Part.export([pf], " & chr(34) & path & nameOUT & chr(34) & ")")
   End Select
  Case "DAE"
   Select Case extOUT
    Case "STL"
     filetxt.WriteLine("importDAE.open(u'" & nameIN & "')")
     filetxt.WriteLine("__objs__.append(FreeCAD.getDocument('" & namePart & "').getObject('Mesh'))")
     filetxt.WriteLine("Mesh.export(__objs__, u'" & path & nameOUT & "')")
    Case "STP"
     filetxt.WriteLine("import FreeCAD, importDAE, Part, Import")
     filetxt.WriteLine("FreeCAD.getDocument('" & namePart & "').addObject('Part::Feature', 'Mesh001')")
     filetxt.WriteLine("__shape__.makeShapeFromMesh(FreeCAD.getDocument('" & namePart & "').getObject('Mesh').Mesh.Topology, 0.1)")
     filetxt.WriteLine("FreeCAD.getDocument('" & namePart & "').getObject('Mesh001').Shape=__shape__")
     filetxt.WriteLine("FreeCAD.getDocument('" & namePart & "').getObject('Mesh001').purgeTouched()")
     filetxt.WriteLine("__objs__.append(FreeCAD.getDocument('" & namePart & "').getObject('Mesh001'))")
     filetxt.WriteLine("Import.export(__objs__, u'" & path & nameOUT & "')")
    Case "IGES"
     filetxt.WriteLine("import FreeCAD, importDAE, Part")
   End Select
  Case "IGES"
   Select Case extOUT
    Case "STL"
     filetxt.WriteLine("import FreeCAD, Part, Mesh")
    Case "STP"
     filetxt.WriteLine("import FreeCAD, Part, Import")
     filetxt.WriteLine("Import.export([pf], " & chr(34) & path & nameOUT & chr(34) & ")")
    Case "DAE"
     filetxt.WriteLine("import FreeCAD, Part, importDAE")
   End Select
 End Select
 filetxt.Close
 If objFSO.FileExists(ConvScript) Then
  FileConv = true
 End If
End Function
DestDir = "C:\Users\ff\AppData\Roaming\FreeCAD\Macro\"
ConvScript = DestDir & "FILECONV.FCMACRO"
CurDir = objFSO.GetAbsolutePathName(".") & "\"
numDone = 0
 nameFile = ControlName(objFSO.GetBaseName(objFile.Name))
  if FileConv(INfiletype, OUTfiletype, INdir & "/" & objFile.Name, objFSO.GetBaseName(objFile.Name) & "." & OUTfiletype, objFSO.GetBaseName(objFile.Name), OUTdir) Then
   sendIN("Please wait..." & vbCrLf & vbCrLf & "Converting:" & vbCrLf & objFile.Name)
   objShell.Run """C:\Program Files\FreeCAD 0.18\bin\freecadcmd"" " & ConvScript, DontShowWindow, WaitUntilFinished
   numDone = numDone + 1
   If numDone = numTot Then
    sendEND("All files processed.")
   End If
   If objFSO.FileExists(DestDir & ConvScript) Then
    objFSO.DeleteFile(DestDir & ConvScript)
   End If
  End If
 End If
Next
Step 3: VBS Arguments
The first argument to pass to script is the file type to convert from (STL, STP, DAE, IGES)
The 2nd one to pass to script is the file type to convert to (STL, STP, DAE, IGES)
INdir = Arg(2)
The 3rd one is the full path of directory containing the files to convert from in the form
C:\***\***\SourceDir (no trailing backslash).
OUTdir = Arg(3)
The 4th argument to pass to script is the destination path in the form C:\***\***\DestinationDir (no trailing backslash).
It's ininfluent that inside the source dir reside other types of files, they're filtered out by the script.
Example:
C:\convert.vbs stp iges C:\myfiles\stpfiles C:\myfiles\igesfiles
Step 4: Here It Comes...
Let's say we have:
- FreeCAD installed
Mine is 0.18 release, so if your is different you'll have to modify the line in script according to:
_________________________________________________________________________
1) Open Command Prompt (cmd.exe)
2) execute (i.e.):
C:\(path to convert.vbs)\convert.vbs stp iges C:\myfiles\stpfiles C:\myfiles\igesfiles
3) a number of info popup, informing you about work progress
4) when done, a new popup will show you how many files have been processed.
That's all!
