Automated Turntable With Steppermotor
Intro: Automated Turntable With Steppermotor
Let's build a simple turntable that rotates light objects precisely and fully automated.
Together with an arduino based controller that will control the stepper motor and the camera shutter, we'll create a powerful tool for automated 360° product photography. The controller is described in a different instructable:
https://www.instructables.com/id/Arduino-Controller-for-Automated-360-Product-Photo/
Now let's start with the turntable.
STEP 1: Gather Parts and Tools and Files
Files (find download links below)
- Parts list and explosion graphic (PDF)
- Eps files for lasercutting (zipped)
Parts
3x Lasercut Acrylic Plates, 3mm thick
Download the template eps-files (see below) and place your order at Ponoko (american/international users) or Formulor (german/european users). Choose one of the 3mm/0.118 inches acrylic P1-Plates in a color you like. For my turntable prototypes, I choosed the material “Acrylic - Black (Matte 1-Side)”. If you have access to an own lasercutting machine or if you want to use a different service, just import the vectorpaths from the eps-files' layer named "Your Design" into your preferred program.1x Bearing „Lazy Susan“
Hole distance top: 81mm
Hole distance bottom: 90mm
Inner diameter: 54mm1x Drive Dog / Diver Disc
5mm inner diameter (must fit to the stepper motor shaft)1x Stepper Motor
NEMA 17 with 5mm shaft diameter
(max height determined by the height of the female-female spacers, see step 4 for further information)4x Rubber Feet
M3, 17x10mmScrews, nuts, bolts
• 4x Countersunk Screws, M3 x 8mm (8mm total length including the head!)
• 8x Pan Head Screws, M3 x 8mm
• 4x Lens Head Screws, M3 x 14mm
• 4x Self Locking Nuts, M3
• 4x Washers M3, 9mm outer diameter (washers should fit into the rubber feet. You can also buy rubber feet with integrated washers)
• 4x Female-Male Standoff Spacer, M3 x 15mm
• 4x Female-Female Standoff Spacer, M3 x 35mm (please note: the height of the "female-female standoff spacer" determines the maximum height of the stepper motor, which is here 35mm.)
I also prepared some kits that include all the parts you need to build your own turntable - except the stepper motor:
https://www.tindie.com/products/FluxGarage/turntab...
Tools
- Some Allen keys
- Phillips screwdrivers
- A drilling machine with countersunk drill
STEP 2: Prepare Acrylic Plates
At first you should peel of the protective foils from the acrylic plates. Sometimes it can be helpful to carefully warm up the foils with a hair dryer.
Since we want to use countersunk screws to fix the "upper plate", we need to prepare the four inner lasercut holes accordingly.
STEP 3: Mount Motor on Middle Plate
Put the stepper motor through the middle plate. Make sure that the holes of the motor match the correct holes in the plate. Use four of the M3x8mm pan head screws to fix the motor.
STEP 4: Add Distant Bolts
Put the 15mm female-male spacers through the plate. Screw the 35mm female-female spacers against them.
Please note that the "female-female spacers" determine the maximum height of the stepper motor, which is here 35mm. If you want to use a higher stepper motor, you have to choose higher standoff spacers accordingly or add additional female-male-spacers. For example, you could add 4 additional female-male spacers with 30mm, this would allow a motor height up to 65mm.
STEP 5: Add Bottom Plate
Turn over the construction and put the bottom plate on top.
Now place the washers into the rubber feet, insert the M3x14mm lens head screws and attach everything to the construction.
STEP 6: Mount Lazy Susan Bearing
Place the bearing on top of the spacers.
Make sure the the bearing's side with the 90mm hole-distance is facing down. Use four M3x8mm pan head Screws to fix it.
STEP 7: Fix Drivedog
Put the drivedog on the motor shaft and tighten the screw.
The drivedog should protrude about 2mm above the bearing.
STEP 8: Add Upper Plate
Put the top plate on the drivedog.
Turn over the construction and place the holes of the bearing to match the holes in the acrylic plate.
Insert the M3x8mm countersunk screws (from below through the hole) and tighten the nuts.
STEP 9: The Final Turntable
If you did everything right, your turntable should look like it is shown in the above 360° image sequence. Sure, this sequence was made with a second FluxGarage turntable and a white acrylic plate on top of it :)
STEP 10: Next Step: Build the Controller
The next step will be to bring the turntable to live. We'll create an arduino + easydriver based controller to control the stepper motor and the camera shutter. Find the detailed instructions here:
https://www.instructables.com/id/Arduino-Controlle...
If you like this stuff, you can find more of this at www.fluxgarage.com
19 Comments
3dbybrunolopes 4 years ago
I've 3 comments about this build.
1. It's very well though out, visually nice
2. The Drive Dog solution. Too specific. Something more generic needs to be addressed just for everyone be able to find the parts. Specially something that someone can find on amazon or more widely available
3. Same for the Lazy Susan bearing, 99% of the bearings you can find have the same hole spacing on top and bottom plates. Yours again, too specific and your design shows this.
I personally have found one with same upper and lower plate hole spacing so I needed to redo the bottom plates to accomplish this!
FluxGarage 4 years ago
thank you for your feedback! Let me add some comments to your points:
1. Thanks!
2. The drive dog is actually a well known part in the RC boat hobby industry, so it should be available widely on the internet. Try searching "drive dog 5mm" at ebay. Another good option is to 3D-print it, since it's a very simple part.
3. Yes, as mentioned above in the answer to onders335, I also wanted to use one of the cheaper bearings with parallel holes, but I assumed there will be problems with the screws from the upper and lower plate, because they might block each other. So I used the quality bearing from "triangle oshkosh" with the different hole positions for the upper and lower plates.
What is your experience so far, does your bearing-solution work smoothly?
onders335 4 years ago
thank you for letting us know!
Initially I also wanted to use a bearing with parallel holes for top and bottom, but I recognized that in this version the screws sometimes get too close to each other and the plate might get stuck. Could it be that the screws are your real problem?
chadfx 4 years ago
Using a stronger motor is one option, therefore you have to add higher standoff spacers between the middle- and bottom plate. For heavier objects, you sometimes also need to fill the tiny gap between the drive dog and the hole in the upper plate to avoid the turntable from shaking when it stops.
I think, it wouldn't make sense to use this turntable for objects more than 1 or 2kgs, but I did not yet test the maximum possible load.
dhruv.adhia 4 years ago
the drivedog I used is actually a part that is used in RC boat technology, so it should be able to tolerate even higher torque forces and rotation speeds without breaking loose.
Did you check that the tiny screw of the drive dog faces against the flat side of the stepper motor's d-shaft? You could also try to add some threadlocker glue that fixes the screw and the drive dog even more.
There are several suppliers of such drive dogs e.g. at ebay. Also, many hobby rc boat suppliers offer such parts. When you buy it, you have to double check that the inner diameter is 5mm (or the actual diameter of your stepper motor, if different).
Sure, there are some other solutions for connecting the motor's shaft to the turntable's upper plate. But realizing them would be a different approach with some efforts, of course.
3D-Printing or creating a custom part on a lathe machine could be an option. Also, you could search for "aluminum mounting hub for 5mm shaft", but this is almost the same as using a drive dog.
I hope I could help you.
I'm using the original "Easydriver" board (with A3967) and the "Big Easy Driver" board from Sparkfun (also the a4998 ). I also added heatsinks and they both still get really hot, but in my case they work fine without burning or exploding :)
Regarding the bearing's noise:
Yes, the bearings itself are un-lubricated. This is what the manufacturer mentions in the description: "Note: Lazy susan turntables are supplied un-lubricated and may sound noisy until lubricated with either oil or grease as determined by your application."
wokawayo 5 years ago
FluxGarage 5 years ago
in the controller's code, the default value for the speed is 0.03 and can be up to 1.00. So the movement can be definitely lots of faster than shown in the videos. I did not yet test the value 1.00 but I guess there will also be some limitations on the hardware side, meaning the easydriver board and the steppermotor.
inconceivable1 5 years ago
well done!
Thank you! Will you build it? :)
nah, I just like to leave a nice comment XD
MissionCritical 5 years ago
really rigid rotating table, i have never seen such a beautiful and robust construction in case of motorized turn tables, great joob!
Thank you! :)
