Introduction: Automatic Beer Pourer
This instructable page will help you to make an automatic beer pourer.
Tools
For this project I needed some tools. The power tools I needed where a soldering iron, a welding post, a drill, metal saw and an engrave pen. The other tools I needed where a screwdriver, a rivet pliers and a knife. Components
LCD displayRaspberry PiLDR(Light Dependent Resistor)
Load sensorLoad sensor amplifierArduino UnoBreadboardJumper wires(Male and Female)Buttons(2)T-cobblerLevel shifterNema17(2)DRV8825(2)PotentiometerResistors100uf capacitor(2)12 volt power adapter
Step 1: Supplies
Tools
Components
- LCD display
- Raspberry Pi
- LDR(Light Dependent Resistor)
- Load sensor
- Load sensor amplifier
- Arduino Uno
- Breadboard
- Jumper wires(Male and Female)
- Buttons(2)
- T-cobbler
- Level shifter
- Nema17(2)
- DRV8825(2)
- Potentiometer
- Resistors
- 100uf capacitor(2)
- 12 volt power adapter
Step 2: Building the Case
I made a case out of metal so al the hardware can fit in easily.
Prototype
First if al I made a sketch, out of this sketch I created a prototype out of cardboard.
Bending
Included you find the dimensions of the metal I used. I bought plates and bent them.
Welding
After the bending I needed to weld everything together.
Then for the last part I drilled holes for the buttons and cut out another hole for the LCD.
For the placement of tubes, you need to drill several holes in a wood board so you can determine the angle.
Step 3: Connecting the Electronics
This part is not that hard, just follow the attached file.
Step 4: Raspberry Pi
The image
Fist of all you need an operation software. We use Raspion OS.
Folow the steps:
- Download Win32 Disk Imager(free software)
- Insert the micro-SD into the computer
- Run Win32 Disk Imager
- Select the iso you just downloaded
- Select 'Write'
Connect the Pi to your pc.
Step 5: Code
In the following link you can find the code needed to run this project.
Everything is explained in the code itself.
Unfortunately, this project does not work optimally, have fun improving it!
