Introduction: Automatic Tissue Opener
From the study from SafeHome.org, there are four common germs in the bathroom. One of the germs among the 4 types of them that exists everywhere in the bathroom called Gram-Negative Rods, is 90% to 95% are harmful to humans and can be resistant to antibiotics! The germs can be carry by air to attach objects, then when people touch the object, the germs will be on their body. Many people care about the germs in the bathroom that would attach to the tissue paper, which is one of the most private things that will be in touch with our body. For example, we use tissue paper to wipe our hands after washing hands, but if there are germs on the paper, washing hands is for no purpose! So the automatic Tissue opener can not just help to storage the tissue, but also helps to block the invisible germs!
So let's start~
All supplies you need:
Arduino Leonardo x1
Breadboard x1
USB Cable x1
HC-SR04 Ultrasonic Module Distance Sensor x1
Servo Motor x1
Male-to-male jumper wires x(many)
Male-to-Female jumper wires x4
Tissue box x1 (or anything you want to put inside)
Tapes
Corrugated boards
(Utility knife, Scissors, decoration paper tapes, or paper if need
Step 1: Connect the Materials With the Arduino Leonardo and Breadboard
Follow and connect the servo motor and distance sensor with the Arduino board as the pictures above
Reminder:
GND is connected to the - and 5V is to the +
Use ~6 and ~7 to connect with the sensor
Step 2: Make the Box
First - Cut the Corrugated Boards With Utility Knife
!The pictures are the order to do the step!
(If there's no HEIGHT mentioned, it means the original height of the corrugated board)
Pic 1~3: Cute the base of the box 12.5(long) x 18.5(width) x14.5(height)
Need THREE, 1 for base and 2 for the sides
Then use the corrugated boards left to cut the other 2 sides
Pic 4~5: Cut the mezzanine that will put in the middle of the box that helps to cover the Arduino board in the bottom of the box and is where the tissue will be put on 12.5(long) x18.5(width)
Pic 4~5: Also, cut the small hole on this board to let the line of the servo motor to get over 1.2x1.2
Pic 6~7: Cut the hole to place the distance sensor 2(long) x4.5(width)
Pic 8: Cut a little hole to let the USB Cable to attach with the Arduino board 1.5x1.5
Then - Stick the boards together with tapes
Step 3: Place the Arduino Board in the Box
After cutting off and stick the Corrugated boards, it should look like Pic 1
Then place the Arduino board and things in their positions
Pic 2: Put the Arduino board inside the box
Pic 3: Place the distance sensor to the hole in the side (which is Pic 6~7 in step 2)
Pic 4: Put the mezzanine on the top of the Arduino board
Pic 5: let the line of the servo motor go over the hole of the mezzanine
Step 4: Make the Cover of the Box and Decoration Time!
I made the cover of the box with a paper and some wood ropes!
Then cut it in the same size as the mass of the box
Stick one side of the cover and the box to make it fixed
And stick some decoration paper tapes on the box to make it looks better
It will look like Pic 2!
Step 5: Code
#include
int UltrasonicSensorCM(int trigPin, int echoPin) //Ultrasonic Sensor Code Auto Generated Return CM max distance 200 { long duration; pinMode(trigPin, OUTPUT); pinMode(echoPin, INPUT); digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH); delayMicroseconds(20); digitalWrite(trigPin, LOW); duration = pulseIn(echoPin, HIGH); duration = duration / 59; if ((duration < 2) || (duration > 200)) return false; return duration; }
Servo servo_pin_2; // create servo object to control a servo
void setup(){ // put your setup code here, to run once: digitalWrite( 6 , LOW ); //set ultrasonic sensor trigPin
servo_pin_2.attach(2); // attaches the servo on pin to the servo object }
void loop(){ // put your main code here, to run repeatedly: if ( UltrasonicSensorCM( 6 , 7 ) <= 15 ) { //當手在15公分或以內的距離感應到超音波感測器 delay( 2000 ); // 伺服馬達會等待兩秒 servo_pin_2.write( 30 ); // 轉30度(打開蓋子) delay( 5000 ); // 等待五秒後 servo_pin_2.write( 130 ); // 馬達會往下轉130度,也就是蓋子會關上 delay( 5000 ); // 再等待五秒,又可以重新再用手感應然後打開蓋子 } }
Link of the code
Step 6: Finish!!!
There are the whole steps! So let's make it and helps to let the tissue cleaner.
