Introduction: Temperature Controlled DC Motor | Arduino TINKERCAD
Hello there
This is my first ever project which i had published on Instructables.
This is the project which have been prototyped virtually using TINKERCAD website.
t .
Step 1: ​Components Used
Components used
Components used procedure
Virtual prototyping:
  1. Arduino UNO R3
  2. Temperature sensor TMP36
  3. NPN Transistor.
  4. DC Motor
  5. Bredboard
  6. connecting wires.
Step 2: Procedure
Connection should be given as per in the picture.
  • First connect power pins to the breadboard
  • connect vcc to the emitter
  • Base to pin5
  • collector to DC motor
  • Connect vout to the analogue inout A0
  • Power and ground connections should be given properly.
Step 3: Programming
#define TEMPERATURE A0
#define MOTOR 5
void setup()
Serial.begin(9600);
pinMode(MOTOR, OUTPUT);
int speed_decider(int temp)
if(temp<35)
return 0;
else if(temp>40)
return 255;
else
return map(temp, 35, 40, 0, 255); }
void loop()
int temperature = analogRead(TEMPERATURE);
temperature = map(temperature, 20, 358, -40, 125);
Serial.println(speed_decider(temperature));
analogWrite(MOTOR, speed_decider(temperature));
Step 4: Working
After giving the same connections you can simulate this on tinkercad.
  • the temperature values are given to the microcontroller as analogue input via pi A0
  • the input value is variable of the function
  • The value is returned to the calling statement on void loop()
  • To the DC motor speed control
  • The speed of motor will be varied from 4360-7800 Rpm with respect to 35-40 degree celcuis.
  • There is no motor driver used here instead of that we are using NPN transistor.
And the real prototype also will work with the same circuit.
