Introduction: Automatic Garden Watering System BY Arduino, LCD, Buttons, EEPROM, Solenoid Valve, Motor and Underground Sprinkler
Now we are making automatic watering plant
I use .5 KW motor which can operate only one sprinkler at a time
so i use this method
which give me positive result
Step 1: Hardware Required
for automation you can add different things i choose Solinoid valve
In this project you will control solidnoid by mobile .
WE will also make it Automatic by timing
if mobile is not present you can also operate with keypad
I also add lcd in the project to see the the present status of Solidnoid switches
hardware required in this project
Android Mobile jumper cables
16 * 2 LCD display
HC-06 Bluetooth Module
Arduino uno or MEGA
Bread Board
10k ohm varible for LCD
Relay Module
For making own relay
Module Relay
Transister Resisters
PCB board
Step 2: Software Required
https://play.google.com/store/apps/details?id=com....
Download this app for automation
it can control 8 relay at a time
Its also have a timer.
To program on arduino use Arduino IDE which is available on
Step 3: Piping Design
Attach all the solinoid with the pipe in parallel
and attach underground sprinkle in series with solidnoid valve
This digram will help you in pipeing
Step 4: Loading Program Witharduino and Relay Module
in this we only use relay module and arduino
I have 15 minin you can also change
in arduino 1 second is equal to 1000
1 min is equal to 60000
change it according to requirement
<p>int timer = 900000; <br>int solid[] = { A0, A1, A2, A3 };
int pinCount = 4; </p><p>void setup() {
for (int thisPin = 0; thisPin < pinCount; thisPin++) {
pinMode(solid[thisPin], OUTPUT);
}</p><p>for (int thisPin = 0; thisPin < pinCount; thisPin++) {
digitalWrite(solid[thisPin], HIGH);
delay(timer);
digitalWrite(solid[thisPin], LOW);</p><p> }
void loop() {
}</p>Attachments
Step 5: Now Adding Start Botton in Arduino
when you press button machine will start at that time
Change the timer setting according to your requirement
1min is equal to 60000 in arduino
change setting according to this
<p>[code]<br>int timer = 5000;
int pinCount = 4;
int sw[]={6};
void setup() {
}</p><p>
pinMode(sw[0], INPUT);
digitalWrite(sw[0], HIGH);
}</p><p>void loop() {
if(digitalRead(sw[0]) == LOW) {
delay(timer);
}</p><p>[/code]</p>Attachments
Step 6: Adding LCD in the Project
NOw i add lcd in the project to see the status of solenoid valve
[code]
#includeLiquidCrystal lcd(12, 11, 5, 4, 3, 2); int timer = 1000; int solid[] = { A0, A1, A2, A3 }; int pinCount = 4; int sw[]={6};
void setup() { lcd.begin(16, 2); for (int thisPin = 0; thisPin < pinCount; thisPin++) { pinMode(solid[thisPin], OUTPUT); }
pinMode(sw[0], INPUT); digitalWrite(sw[0], HIGH); }
void loop() { lcd.setCursor(0, 0); lcd.print("M1 OFF"); lcd.setCursor(8, 0); lcd.print("M2 OFF"); lcd.setCursor(0, 1); lcd.print("M3 OFF"); lcd.setCursor(8, 1); lcd.print("M4 OFF"); if(digitalRead(sw[0]) == LOW) { lcd.setCursor(0, 0); lcd.print("M1 ON"); digitalWrite(solid[0], HIGH); delay(timer); digitalWrite(solid[0], LOW); lcd.setCursor(0, 0); lcd.print("M1 OFF"); lcd.setCursor(8, 0); lcd.print("M2 ON"); digitalWrite(solid[1], HIGH); delay(timer); digitalWrite(solid[1], LOW); lcd.setCursor(8, 0); lcd.print("M2 OFF"); lcd.setCursor(0, 1); lcd.print("M3 ON"); digitalWrite(solid[2], HIGH); delay(timer); digitalWrite(solid[2], LOW); lcd.setCursor(0, 1); lcd.print("M3 OFF"); lcd.setCursor(8, 1); lcd.print("M4 ON"); digitalWrite(solid[3], HIGH); delay(timer); digitalWrite(solid[3], LOW); lcd.setCursor(8, 1); lcd.print("M4 OFF"); } }
[/code]
Step 7: Set Time by Using Two Button and EEPROM
Now i add two button to set time
now you can set time by button LCD is present
one button is for time up and is for time down
#include <LiquidCrystal.h>
#include <EEPROM.h>
int pinCount = 4;
int sw[]={6};
int st = EEPROM.read(1);
int swt[] ={7,8};
void setup() {
lcd.begin(16, 2);
}</p><p> pinMode(sw[0], INPUT);
pinMode(swt[0], INPUT);
digitalWrite(swt[0], HIGH);
pinMode(swt[1], INPUT);
digitalWrite(swt[1], HIGH);
void loop() {
int timer = EEPROM.read(1) * 60000;
lcd.print("SET Time");
lcd.print(st);
lcd.setCursor(4, 1);
lcd.print("MINUTES");
if(digitalRead(swt[0]) == LOW) {
EEPROM.write(1, st++);
delay(1000);
lcd.clear();
if(digitalRead(swt[1]) == LOW) {
EEPROM.write(1, st--);
delay(1000);
lcd.clear();
lcd.clear();
lcd.print("M1 ON");
delay(timer);
lcd.print("M2 ON");
delay(timer);
lcd.print("M3 ON");
delay(timer);
lcd.print("M4 ON");
delay(timer);
lcd.clear();
}Step 8: Troubleshooting and Feedback
IF any problem arises contact me through inbox
Kindly give me feed back i like when some one give feedback
