Introduction: Automatic Generater Starter
We mostly have generator at our homes but the main problem is on/off
Step 1: Normally How We Start Generator
when electricity gone
first
we switch off the main switch or breaker
second
if the generator is small or up to 1 kva we also switch off all the home appliances like Refrigerator, Ac and manyother things
Third
we turn the fuel valve open and then start the generator
Forth
After starting Attach the wire with the home
Fifth
When light come we first switch off the generator Close the fuel close.
Sixth
Switch on the Main switch
Step 2: What Problem Arrizes in This
shock
You may cause a shock
Human Error
forgot to switch off the main switch
after switch off the generator forgot to turn off the fuel.
No Alert for generator getting heating up
this Act damage the generator from in side
Step 3: Hardware Required for Making It Automatic
Arduino UNO
Solenoid Gas Valve
220 v Relays
12v Relay
5 v Relay module
220 v Contractors
Step 4: Now Manual Start and Automatic Off
in this diagram i made manual start and automatic off
First make this after that we will Modify to make it automatic by using arduino
For making this I use
120 A 8 pin Relay
to stop generatori use
5 pins small relay
to start use push button or Key of generator
Step 5: Now Adding Arduino in This Project
now assemble hardware like this to make generator auto start
In this you have to use
2 relay 220 v As a sencer for Arduino
1 relay module for starting generator
In this diagram I only modify the previous step (manually on and automatic OFF)
Now in this Auto start and Auto Off
In next step We put sensors and Protection
Step 6: Now Loading a Program on Arduino
now upload this code in the arduino
int ch1 = 6;
int ch2 = 7;
int ch3 = 8;
int ch4 = 9;
int ch5 = 10;
void setup()
pinMode(ch1, OUTPUT);
pinMode(ch4, OUTPUT);
pinMode(ch5, OUTPUT);
pinMode(ch2, INPUT);
digitalWrite(ch2, HIGH);
pinMode(ch3, INPUT);
digitalWrite(ch3, HIGH);
void loop()
if (digitalRead(ch2) == LOW)
{ // switch is pressed - pullup keeps pin high normally
digitalWrite(ch1, LOW) ;
digitalWrite(ch4, LOW) ;
digitalWrite(ch5, LOW) ;
else
digitalWrite(ch4, HIGH) ;
delay(1000);
digitalWrite(ch5, HIGH) ;
if(digitalRead(ch3) == HIGH)
delay(3000);
digitalWrite(ch1, HIGH);
delay(3000);
else
digitalWrite(ch1,LOW);
