Introduction: Automatic Lego Color Sorter
About: I am Studying Artificial Intelligence at Howest in Kortrijk. Born in 2004 o_o
Tired of sorting LEGO on your own? Do you want it to be sorted for you?
Introducing the Smart LEGO Sorter, a machine that will sort Lego bricks by color to make building Lego sets easier for everyone, especially for colorblind people.
How does it work?
You put a brick at the beginning of the treadmill. That brick will move through the machine and pass a camera that will use AI to determine which color the brick is. Then it will travel further, and the flaps will sort the Lego bricks by color. For this mockup, it's sorted into two colors.
For this instructable, you will need these things:
  • Laptop
  • Raspberry Pi 5
  • Freenove project kit for raspberry pi
  • 32gb micro sd
  • Webcam (Trust trino 720p)
  • cables
  • 1x Stepper motor
  • 2x servo motors
  • 3d prints (Files are attached with each step)
  • 4x metal pins(stiks) 3mm diameter
  • Black elastic synthetic fabric
  • 8x 8mm outerdiameter x 3 innner diameter x 4 mm bering
The price for these things is +- 220 euro. For more clearence see the pdf.
Step 1: Print the Mainframe Parts
For this part, you will need to print some things.
You can choose the color you want.
I recommend using PLA for the 3D printer.
Step 2: Gluing the Parts Together
You will need to take every mainframe part and glue them together. I recommend doing it piece by piece.
Step 3: Bottom Plates
Print the bottom plates and glue them to the bottom of the mainframe.
Why?
I work with the bottom plates to give the frame more sturdiness so it will be a little bit stronger.
Step 4: Print the Rolls and the Gear
Here you need to print the rollers (3 times) and the gear for further construction.
I designed the gears to have a 1/3 gear ratio.
Why the 1/3 ratio?
The stepper motor has a lot of torque but not a lot of speed. I wanted to speed it up with the ratio.
Step 5: Put the Bearing in the Rolls and the Treadmill Gear.
I designed the prints so that the bearings will fit perfectly without any glue required.
I use the bearings so the roller has less friction to roll across the metal sticks, which in turn makes the machine run smoother.
Step 6: Put the Stepper Motor in the Frame
Put the stepper motor in its holder and thread the cables of the stepper motor through the small gap underneath the holder.
Running the cables through the gap will make it cleaner to look at.
Step 7: Print Servo Stands
Glue the servo stands like this and then glue the two servos on.
These are the little flaps that will sort the LEGO bricks after the AI detects the color
You can put the stick already on the servo's..
Step 8: Fabrick Treadmill
You need to stitch the black fabric together +-1meter
Step 9: Rols on the Frame
  1. You need to put your homemade treadmill band in the frame.
  2. Place the 3 rollers and the treadmill gear inside the rubber loop.
  3. Glue each roller into the pre-made notches.
Step 10: Print the Camera Holder
This is for the camera holder. You will see that I use clips; this makes the design process easier for me and makes it much easier to carry around because I can take the holder apart.
Step 11: Put the Camera in the Holder
Step 12: Put Everything Together
The four legs of the camera holdder should fit perfectly in (cameraholder mainframe) I also did it this way to make carring it around eazier.
Step 13: Connect Everything
Stepper Motor:
  • Just plug the connector into the connector of the Freenove kit.
Servo Motor:
  • Orange wire = Programming pin
  • Red wire = 5V
  • Brown wire = Ground
  • Make sure the servo closest to the camera holder is servo 1.
Servo 1:
  • Connect the red wire to a 5V pin and the brown wire to a GND. Connect the orange wire to GPIO16 (keypad). Note: I used extra cables to extend the servo pins.
Servo 2:
  • Connect the red wire to a 5V pin and the brown wire to a GND. Connect the orange wire to GPIO20 (keypad). Note: I used extra cables to extend the servo pins.
Step 14: Computer Code
This is a link to my github fot the code of the raspberry pi
Download the RPi folder and run the code app.py and ENIOY
https://github.com/howest-mct/2023-2024-projectone-ctai-VandemeulebrouckeRoan/tree/67695aa7c6d4f9d4f2211d8be84412e6e97e1b24/RPi
Step 15: How Did I Make the Ai?
Step 1.
Gather a large dataset of LEGO brick images (e.g., 300 pictures with an average of 11 bricks per photo).
Step 2.
Use Roboflow to annotate the images. Annotation involves drawing boxes around each object you want to track. For my project, I used 5 classes: Red, Orange, Blue, Green, and Yellow. I drew a box around each brick and labeled it with the appropriate class.
Step 3.
Export the annotated dataset once you’ve completed the annotations.
Step 4.
Use Python to train a model with the annotated dataset and evaluate its accuracy.
Step 5.
Once the model is trained, you can build a program around it. You can use ChatGPT to help modify the code if you need to sort different colors.
