Introduction: Automatic Lighting Box With a Timer on Battery
I propose a simple lighting scheme of the kitchen drawer to turn off the timer. The backlight is switched on for 15 seconds. (that's enough for me)
Step 1: You See a Box With Light and Without
Hi
Step 2: We Need:
- Magnetic contact 3 pins
- Magnet D15H4
- Transistor IRF840 (It can be any n-MOS transistor)
- Resistor 500 Ohm
- Resistor 300 Ohm (you can not put)
- Resistor 20 Ohm (to reduce current LED strip - you can not put)
- The capacitor 16c 22mkf
- 25cm LED strip
- 8pcs AA batteries (rechargeable batteries can not be used - high self-discharge)
- 1 m double wire.
Step 3: The Scheme Is Very Simple
Step 4: How Does the Magnetic Contact
As I approached a magnet contact switches
Step 5: Solder the Resistor to the Transistor
Step 6: Solder the Remaining Parts of the Scheme
Step 7: Solder the Wires to the LED Strip and Connect to the Timer
Step 8: Assemble Battery Pack
Step 9: Test Duration and Current
Step 10: Set in Place and Glue LED Strip
Step 11: And Put a Magnet in Front of the Magnetic Contacts
Step 12: You Can See the Result.
With and without illumination.
More details you can see on the video.
Thank you for attention.
