Introduction: Automatic TNT Launcher
auto TNT launcher
repeaters
sticky pistons
slime blocks
redstone dust
obsidian
dispensers
Step 1: The Beginning of the End
First place a stone button (any button works but DO NOT USE A LEVER THIS IS IMPORTANT!) Then place 3 redstone in a straight line from the button, then place a repeater in front of the redstone, the put the dispenser.
‼️MAKE SURE THAT THE REPEATERS FACE WITH THE ADJUSTABLE PART FACING EACH OTHER‼️ LOOK AT IMAGE FOR A REFERENCE
On the first redstone closest to the button put two repeaters back-to-back with max ticks (3 clicks). Then place another redstone in front of them. On the right side of it put another repeater at max ticks, then another redstone piece in front of that, on the right side of that redstone put another repeater at max ticks then another redstone piece to connect it all.
Step 2: The Propeller
At the bottom left corner of the repeater from the previous step, put a redstone piece facing left, then put another repeater at max ticks after that put another redstone piece. now dig down 1 block in front of that redstone piece put a redstone there in front of that, dig two blocks down put another there. in front of that dig another two blocks down and put a sticky piston facing up with a slime block on it.
Make sure that you can see all sides of the piston, that means it can activate, use picture as reference.
Step 3: Extending the Build
From where you put the redstone that heads down to the piston put two pieces on the left side of the other piece, then on the second piece of redstone put a repeater facing forwards, this one will have 2 clicks not 3
Then put 6 obsidian up on top of the dispenser
Step 4: The End of the End
do this first put a slime block on top of the 6 obsidian with a piston facing it behind it, do that any way you want to. the put a repeater facing the piston.
The next part for the redstone the more compact it is the better just make sure the redstone at the top is 2 blocks away from the repeater for without it, the signal stays causing it not to repeat.
Step 5: GIF Example
If anyone has an idea to make it better let me know in the comments
