Introduction: Automatic Watering System With ESP32
Hello everyone, today I will show you how to make your own automatic watering system witth esp32 using the blynk app. You can water your plants even when you are away. Let's get started
  • ESP 32
  • Mini water bucket
  • Jumper Wires
  • Aquarium Hose
  • 5 Watt Power Supply
  • 5 Watt Relay
  • Wires( for Fixing the hose to the plant)
  • 5 Watt Water Pump
Step 1: TEST YOUR COMPONENTS
Test your components using the voltmeter and make sure that everything works fine
Step 2: CODE THE BOARD
First, make sure you have Arduino IDE on your computer. Here is a quick tutorial on how to setup Arduino IDE to work with your ESP Board if you haven't done it yet.
And here is the code;
Step 3: ASSEMBLE ALL THE PIECES
Assemble all the pieces like I showed you in the diagram
Step 4: Pdf File
And here is the pdf file of the outside box. I made it out from 3mm mdf you can easily lazer cut this to achive the box that I made
