Introduction: Automatic Wire Cutter and Stripper
A desktop machine that will measure out a length of wire and strip a length from either end.
Why?
To create lengths of wire that fit perfectly into an electronics breadboard. (we produce kits and you can only hand cut and strip so many wires before you go crazy)
This is also the first item in a concept oomlout.com is working on dubbed "open manufacturing" or "micro-manufacturing" we're still discussing the name. (more to follow)
How?
It breaks down into three parts
1. Wire Feeder - This feeds the wire in measured lengths forwards and backwards (uses a stepper motor)
2. Wire Stripper - This runs an exacto knife blade around the insulation of the wire twice. (uses a small servo motor and normal sized servo motor)
3. Wire Snipper - Snips the wire at the end. (uses a pair of wire cutters and a cheap handheld drill motor)
(I fear a full instructable for something so niche seemed like a little bit of overkill, but if you'd like to make your own the files I used can be found here: http://www.thingiverse.com/thing:268 )
Why?
How?
